Data system replica front lip installation(DIY)
Old Sep 1, 2007 | 10:11 PM
noizedskyline's Avatar
Guys, I need help on installing this front lip so I don't have to go to a shop. Actually, I just need to know where the hardware goes.
I'm assuming the 4 phillip head screwes goes into the 4 holes of the lip and they screw underneath the bumper.
I'm not sure where the two hinges(gold color) with bolt that goes through it goes. Do they go at the very end of the lip that wraps behind the front fender, therefore I would have to drill a hole?
Any help would be appreciated, thanks
Old Sep 1, 2007 | 11:19 PM
by15vc's Avatar
not sure about yours but with my illusion lip which is basically the data replica, i had 4 screws drilled into the sides where the lip wraps around the front fender (2 on each side) and also a bar-like support (which i would assume is what your hinges are for) underneath the lip to give the middle some support. hope this helps
Old Sep 2, 2007 | 04:02 AM
thanks
EnCr1pt3d
Jul 8, 2019 02:48 PM
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
papo020
Jul 17, 2015 10:30 PM
djreinx
Jul 13, 2015 05:04 PM
