Debadging questions
Old Sep 4, 2007 | 04:27 PM
darich's Avatar
Debadging questions
Hello, I have two questions about debadging. When using the dental floss or fishing line to remove the badges, do you place it between the badge and the adhesive, or between the adhesive and the body of the car? Second, is it true that the mt. fuji logo on the trunk of the car is bolted to the car? Thanks in advance.
Old Sep 4, 2007 | 05:03 PM
Calvin's Avatar
Overglorified Altima
1) doesn't matter. remove all excess glue with googone or wd40.
2) on sedans, yes.
Old Sep 4, 2007 | 05:52 PM
WILLIE BEANS's Avatar
Theres No Way You Can Get All The Adhesive Off With Either
You Should Use Goo Gone To Remove Whatever Is Left
I Never Tried Wd40 ..
Old Sep 4, 2007 | 05:57 PM
ndlive's Avatar
yep. i tried wd40, didn't really work for me. i just used adhesive remover and my fingers to roll it off my fingers and nails were f'ed up afterwards lol good luck!
Old Sep 4, 2007 | 07:09 PM
darich's Avatar
Originally Posted by aHero4Eternity
2) on sedans, yes.
Bummer. I wanted to remove it. Oh well, at least there will be one emblem on the back, and one on the front.
BTW, I used WD-40 to get masking tape off of my wife's car when it was decorated for our wedding. It was 110 degrees that day and the masking tape cooked on. The WD-40 did a great job taking the tape residue off.
Old Sep 5, 2007 | 04:23 AM
Meatshackle's Avatar
Deep Sea Moderator
WD40 worked well for me also.
Old Sep 6, 2007 | 09:11 PM
Mr. Samster's Avatar
i just used nail polish remover and finger nails...
Old Sep 6, 2007 | 09:22 PM
O HELLA OEM's Avatar
i just took my infiniti emblem and g35 emblem with my nails haha came off real easy. then i got GOO GONE from AUTO ZONE and took the excess tape off my trunk. real easy.
Old Sep 6, 2007 | 11:39 PM
bigc's Avatar
Wings Nation
rubbing alcohol works really well to take off the remaining adhesive. whatever you use, however, make sure to clean the area thoroughly afterwards.
Old Nov 20, 2007 | 02:27 AM
John6mt's Avatar
goo gone will not ruin the paint?
Old Nov 20, 2007 | 02:30 AM
Calvin's Avatar
nope.
googone, wd40, peanut butter, whatever...
Old Nov 21, 2007 | 08:25 PM
mpspeer's Avatar
Patrick
Is there an easy way to remove or get rid of the "Ghost" letters that are left behind from debadging? You can still see remains of my "Infiniti" letters, though I took them off about 2 to 3 weeks ago... and yes, I took all the glue off as well. Steps to doing this would be awesome.
Old Feb 21, 2008 | 10:58 AM
mt7rabbit's Avatar
WD40 did nothing but make the glue a slippery mess. As far as the ghost letters, I can't help you there.
Old Feb 21, 2008 | 11:27 AM
sfgr415's Avatar
I just washed and waxed the car afterwards. The ghosting was still there for a bit. I ended up needing a full detail and I never saw the ghosting again.
Old Feb 21, 2008 | 11:52 AM
shibal_z's Avatar
I'd say debadging works best during the summer when the sun will heat up the panels and soften up the adhesive. The other method is to use a heat gun or blow dryer.
