Lower Bumper Grill Removal
Old Oct 31, 2007 | 10:17 AM
speedgeek's Avatar
Hi,
Is it possible to easily remove these black bumper grills? If so how? Thanks!!!
Old Oct 31, 2007 | 10:49 AM
k67p67's Avatar
They must be cut out. Use a Dremel tool. If you go with an aftermarket grille, you can have all the mesh match like this:
Old Oct 31, 2007 | 11:06 AM
Calvin's Avatar
Overglorified Altima
+1 for dremeling them out.
Old Oct 31, 2007 | 04:09 PM
speedgeek's Avatar
Thanks Guys!!
Old Dec 2, 2007 | 12:14 AM
jimmyshaker's Avatar
I couldn't find a DIY to answer these questions so hopefully someone here can...
When you Dremel out the OEM mesh, do you have to leave the ring, the part that outlines the opening, in the bumper?
Has anyone removed that ring? If so, how'd it look?? Better to leave the ring in??
Thanks!
Old Dec 2, 2007 | 02:10 AM
k67p67's Avatar
If you look closely at the grille opening, you'll see where you'd have to cut if you kept the ring as opposed to removing it. If you remove it, you'll expose a cut surface that would be visible. If you keep the ring, the cut surface faces the rear of the vehicle and cannot be seen.
Old Dec 8, 2007 | 08:46 AM
So basically, I cut the grill out, then sand down the remaining parts of it so that it becomes even with the ring part?
Old Dec 8, 2007 | 01:08 PM
k67p67's Avatar
It's a little difficult to explain. Just remember that the circular blade of your Dremel will remain vertical while cutting. You should be able to figure it out by looking at the grilles.
Old Dec 8, 2007 | 01:39 PM
citymunky's Avatar
Originally Posted by k67p67
That look good,
Old Apr 23, 2008 | 01:03 AM
Mr Inkredibul's Avatar
So do you have to remove the bumper to dremel out the oem lower grills?
Old Apr 23, 2008 | 02:28 AM
savefatkids's Avatar
yess. and be careful not to cut too much
Old Apr 23, 2008 | 07:27 AM
Do you have to remove the stock lower grills to install the street scene lower grills?
Old Jul 16, 2008 | 03:28 PM
RST531's Avatar
I know im bumping an old thread, but i didnt want to start another one since the ppl who replyed has the info i need.
What is best to secure the wires on an OEM bumper for the new mesh?
Hot glue, Silicone, JB weld, or something else?
Since the OEM bumper is not fiberglass I'm not sure which is best.
Old Jul 16, 2008 | 03:30 PM
MikeYo's Avatar
Very clean how it matches the top grille.
Old Jul 16, 2008 | 03:35 PM
ShanesG's Avatar
Hot glue should work just fine!
