What to use when re-badging?
Old Nov 1, 2007 | 07:22 PM
GBeast's Avatar
Double sided tape didnt do the trick. Is there a type of glue that i could use? Better yet, what do they use from the factory? Thanks
Old Nov 1, 2007 | 07:28 PM
Calvin's Avatar
Overglorified Altima
What kind of double sided tape did you use? It should have worked perfectly.
Old Nov 1, 2007 | 07:33 PM
zackt69's Avatar
rarejdm.com
^+1
They should have double sided tape at the auto parts store... 3m tape, that is for automotive use and should resist water better. Don't use glue... double sided tape should be more than good enough.
akachi's Avatar
3m double sided tape.. u could get these from staples
Old Nov 1, 2007 | 10:04 PM
GBeast's Avatar
I used the 3m double sided tape, but it made the emblems stick out too far and it looked awkward. Any one know what kind of glue they use from factory?
Old Nov 1, 2007 | 11:05 PM
Calvin's Avatar
They use double sided tape.
Old Nov 2, 2007 | 02:23 AM
savefatkids's Avatar
did u scrape off all the old tape before you put the new one?
Old Nov 2, 2007 | 04:42 PM
GBeast's Avatar
For the mt fuji yes, infiniti letters no. Even then it stuck out. Some of the letters were flimsy, particularly the "I"s
Old Nov 2, 2007 | 05:06 PM
thats wierd.. when i did mine it came out fine but i only did the mt fuji emblem
Old Nov 2, 2007 | 08:20 PM
DrewTheSuit's Avatar
agreed^^^ i used 3m tape as that is what comes from the factory, check around to see if they have some that is not as thick if your letters are sticking out too far, but that's what i rebadged with
Old Nov 5, 2007 | 01:16 AM
EricIsKlumzyee's Avatar
3M tape but you need to cut them to make it fit..
InTgr8r
V36 Interior, Exterior & Lighting
Jun 30, 2010 11:54 PM
OCG35
Jul 8, 2008 05:34 PM
Otacon132
Dec 31, 2006 11:19 AM
Chad@infinitispecialists
Exterior-Vendor
28
Nov 13, 2006 04:17 PM
Daddylongstroke
Nov 14, 2003 10:40 AM
