DIY for Splash Guard?
Old Feb 20, 2004 | 01:31 PM
DaN_the_MaN's Avatar
Asking for another DIY guys, haha. I am going to be ordering a set of splash guards from Grubbs. I called my local dealership in San Diego and they quoted my $92 for the install. I laughed and hung up.
Anyone know where I could find a DIY or can someone explain the whole process to me? Does it require any kind of drilling?
Thanks
Twilight Blue G35 Coupe 6MT
Premium - Nav - Aero - Trunk Mat
Injen CAI
Old Feb 20, 2004 | 01:55 PM
Meatshackle's Avatar
Deep Sea Moderator
Re: DIY for Splash Guard?
The instructions included are very good and self-explanatory. You do need to drill I believe 4 holes total, into the plastic of course. You will also need to jack up your rear end and remove the rear tires unless you have a 90-degree drill. If you take your time you can do this in about an hour.
Russ
Black 6MT Coupe
Jax, FL
PS2 and Headrest Monitors Thread
Old Feb 20, 2004 | 02:21 PM
I saw someone post on FreshAlloy that they didnt drill at all and just taped the Splash Guards on using extra 3M take, so that later he could take them off.
I was wondering if I could do this as well. Will they fall of over time?
Could I use the standard jack that comes with the car to jack up the front and rear? I do have a drill at home and an extension, but I dont know what you mean by 90 degree extension?
Btw, the guards are $75 per set. Is this a good price?
Injen CAI
Old Feb 20, 2004 | 02:34 PM
redwillow's Avatar
20 Year Member
i wouldn't try to just tape them. They will prob fall off.....
yes you can just use the oem jack...and i was able to get mine on in the rear with the tires still on. I just used a very long bit extension and angled the drill. I jacked the front up slightly to drill the bottom holes. But if you have a right angle drill (and use a short drill bit) it is possible to do all of them without jacking or removing the wheels. Of course, some people may still find it easier to remove the rear wheels, if you aren't very handy with a drill.
03 6MT coupe, red/willow, premium, aero, splash guards, alum pedals, clear corners, 15% tint
Old Feb 20, 2004 | 02:47 PM
Ok, I dont think I have a right angle drill. By this, do you guys mean those long scredriver type hand held drill's that bend in the middle? Or do you guys mean the extention actually bends for the drill?
Injen CAI
Old Feb 20, 2004 | 07:18 PM
Deep Sea Moderator
You can still remove the splash guards even if you drill and you're not going to leave huge holes. There will be one small hole in the rear, the rest are under the car.
Russ
Black 6MT Coupe
Jax, FL
Marlin84
Apr 1, 2020 12:52 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
Kelvin Style006
May 23, 2016 03:47 AM
Jon81035
Sep 16, 2015 04:58 PM
