TWO (2) quick questions!!!
Old Dec 7, 2007 | 07:50 PM
blackg3504's Avatar
first i just received my clear corners they look great but i cant find the DIY thread....just dont wanna do anything i cant fix. and number 2 is I wanna up grade my headlights and found a great local deal (well what i think is a great deal)...OEM G35 Couple Headlight set, ballast, bulds all for 400 bucks! so is that a good deal or what?
Old Dec 7, 2007 | 07:52 PM
EricIsKlumzyee's Avatar
Clear corners..
1. face your clear corner
2. Pull on the corner..
3. Corner falls off
Head Lamps
1. If they're 03-05 head lamps (non projector) that is not a good deal
2. if they're 06-07 head lamps then yes they are a pretty good deal if it includs everything.
3. iono
Old Dec 7, 2007 | 07:54 PM
blackg3504's Avatar
i believe they are 03-05 projector. and thanks for the help....i feel really dumb now LOL
jiggafree's Avatar
your OEM corners pop right off and your clear pop right on. just pull.
i think you can find used 03-05 headlights for cheaper
Old Dec 7, 2007 | 08:15 PM
ehh let me rephrase that
$400 (unless you're buying from a dealer) They should:
1. Include ballasts
2. Include Bulbs
3. Look 100% Perfect
A new set is about $600 without ballast and bulbs (but seeing how you probably already have a G35 you can just transfer everything over.)
- Eric
Old Dec 7, 2007 | 08:18 PM
Polishthrust's Avatar
U guys just pull on the corner? I always put my finder behinf the bumper and pop the metal clip from the inside.
Old Dec 7, 2007 | 08:25 PM
Calvin's Avatar
Overglorified Altima
did you check the DIY forum...?
https://g35driver.com/forums/body-interior-exterior-lighting-diy/132611-diy-clear-corners.html
wow, way too much work....
^just pull on the corner.. if you uninstall and reinstall by pulling it off a couple of times and it starts looking loose.. just read adjust the tabs..
Old Dec 8, 2007 | 04:14 AM
Xblackg35X's Avatar
03-05 didnt come with projectors
408G35Sedan
Feb 23, 2022 06:46 PM
skippyG
Jan 25, 2016 01:18 PM
Th611
Oct 27, 2015 03:48 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Soumilg
Jul 18, 2015 12:33 PM
