Brake light or what?
Old Jan 18, 2008 | 12:54 AM
ScubaSteve312's Avatar
Originally Posted by doctorG
I don't think there's a fuse just for the rear window brake lights.. The lights were probably ghetto rigged and spliced up to hook up to the spoiler LED's.
yea probably
either way theres a 90% chance the owner sabotaged it
Old Jan 18, 2008 | 10:05 AM
bassholic's Avatar
If this is sarcasm then you are forgiven, if not your a fukin idiot. The dealer would be the one to put the stock spoiler on when it comes out of the port. Granted some technicians could "ghetto rig" it. But then again the 60yr old g-mom who had the car could have done the wiring
As with everything there are different scenarios, but for the most part i think many people w/ 2 brake lights have it b/c of the dealer and wanting that option added
Old Jan 18, 2008 | 06:25 PM
overdrve's Avatar
When I ordered my G in 2005, there were 3 options in regards to the spoiler.
1) Factory aero kit complete. Included spoiler and diffusers installed at the factory in Japan. With this option, they delete the inside 3rd brake light. This is the option I went with because I couldn't stand having a dead light mount in the middle.
2) Port installed spoiler with diffusers. This is a more common option for non custom orders. Cars are mass produced without the spoiler. That's why you have the 3rd brake light. A certain amount of dealer orders get the spoiler and diffusers installed at the port. However, Infiniti never produced a new rear deck shelf replacement that specifically removed the light. Plus, it is a pain in the rear to remove that deck shelf in our car.
3) Dealer installed option for spoiler. This may or may not include the diffusers depending on how shady your dealer was. In this case, they take a non-spoiler G and install one. OEM or aftermarket. The trunks are pre-wired for the brake light. So depending on the install, you may have both wired up or just the spoiler.
Personal opinion (some which are agreed upon many here on the forums), if you have a spoiler option added, don't also wire the inside brake light. Sure more light gives that extra alert to the people following too close behind you. But it just doesn't look right having 4 brake lights. You end up with a massive rear-end of red. But that's personal opinion.
For those of you who want that light to be lit again, I'm sure it is as easy as plugging it back in. Not sure where though as I don't have one.
Hope that info helps any of you... I'm sure your lights aren't broken.
Old Jan 18, 2008 | 08:07 PM
Beebo's Avatar
^+1
Old Jan 18, 2008 | 08:28 PM
TIAN's Avatar
Hold The Line
+1 I disconnected my rear window brake light. If you want to turn it on get behind your seat and squeeze the housing on both sides and pull out. Connect and play.
11bEMT
May 27, 2022 03:13 PM
SiMpLyMoDiFiEd
The FX-Spot
Dec 2, 2021 04:35 PM
mike730
Jan 12, 2018 04:25 PM
linedr89
Aug 17, 2015 05:11 PM
Lsantana757
Jul 20, 2015 09:08 AM
