View Poll Results: What should I paint?
Paint INSIDE
24
75.00%
Paint OUTSIDE
25.00%
Voters: 32. You may not vote on this poll
I got IP Coupe.
I want to paint my engine cover.
Should I paint outside IP and live middle the way it is
Should I paint inside IP
And Q to those who did it.
Do I have to use Hight heat paint and primer or no?
and what is the easiest way to mask out the letters and INFINITI sight if I end up painting the middle?
CandlestickPark
ill Sedan
close
- Join DateJun 2007
- LocationLong Beach, SoCal
iTrader Positive Feedback100
iTrader Feedback Score(87)
Liked:2,688 Times in 1,449 Posts
I like the look of the second one. Inside painted in IP, looks pretty sweet.
Quote:
I like the inside also but it's more taping and masking. Originally Posted by CandlestickPark
Quote:
Don't be lazy..........Paint the inside!Originally Posted by JOKER
Joker, just tape over the Infiniti signs & use a razor blade to cut the tape along the edges off.
Quote:
I got only oneOriginally Posted by KapVu
inside, paint the battery covers white too.
I like No.2. You should probably use heat resistant paint just to be safe.
Option No. 2 inside definitely! More work yes, but others will notice that extra work!
Joker.....#2 all the way.....
I'm sure you can tape off the numbers.....go to an auto paint supply store and buy a couple different sizes of tape.
They sell some 1/8" blue pinstriping tape, that will let you follow the outline perfectly.
I would scuff the cover with scotch pad or fine steel wool, then prime and paint.
I'm not sure if you really need engine paint since the air cleaner doesn't really generate any heat by itself....
Good luck
Good luck
