DIY mesh install
Mar 24, 2008 | 02:38 PM
Does anybody have a DIY to install a mesh on a urethane replica nismo bumper? I plan on using screws but i dont know where to screw them into the bumper.
Reply 0
Mar 24, 2008 | 02:44 PM
usually @ the four corners of the opening but it all depends on how thick the urethene is at those points if anything you have to go to bodyshop supply store and get a special adhesive that bonds to urethene it look almost like a caulking tube
Reply 0
Mar 24, 2008 | 09:00 PM
Raj- did u finally get your mesh? g/l on the install
Reply 0
Mar 24, 2008 | 09:17 PM
there should be 6-8 'hard points' around the opening where you can install small screws.
Reply 0
Mar 25, 2008 | 12:03 AM
Quote: Raj- did u finally get your mesh? g/l on the install
yea man Rich refunded the money and i ordered it from customautomesh. Thanks for the tips guys.
Reply 0
Apr 10, 2008 | 09:08 PM
just make sure you dont use lond screws make sure that are short screws! you will crack your paint if you use long screws i mean get really shorts screws for installation
Reply 0
