impul sides
Mar 31, 2008 | 01:00 PM
hey, im planning on getting nismo front and impul sides for my coupe. does anyone who has this combo or has the impul sides have problems with scraping? im lowered on eibach prokit springs and have 19" wheel's. i seem to scrape alot in the middle part of the car.. i know the impul is a bit lower than stock so i was wondering if there is alot of scraping problems with it. thanks
Reply 0
Mar 31, 2008 | 02:22 PM
haha aiight sounds good. thanks. anyone else? lol
Reply 0
Mar 31, 2008 | 02:24 PM
your not dumped so you prob. won't have a problem with scraping, just watch where you are driving and it shouldn't be a problem.....get them
Reply 0
Apr 1, 2008 | 02:16 AM
well if you scrape now with the stock sides you will scrape with the aftermarket sides...
Reply 0
Apr 1, 2008 | 02:24 AM
^+1 Yeah, if you hit with stock sides, you'll hit with the Impul sides. The Impul sides aren't too much lower in the center of the sides, but right where the sides start (after the front tire), they hang down pretty low.
Reply 0
Apr 1, 2008 | 02:26 AM
I scrape the middle of the car alot also, but its not the sideskirts, its the metal underbody. Look under your car and make sure that you are actually scraping your sideskirts
Reply 0
Apr 1, 2008 | 10:11 AM
The Nismo front + Impul sides is a very common combo. Search "savefatkids" for one example.
I scrape my Impul sides all the time.
Reply 0
Apr 1, 2008 | 10:51 AM
is it ok to scrape the metal underbody? i used to sit on eibach sportline and i would scrape the underbody just going over slightly higher bumps or a steep incline.
Reply 0
Apr 1, 2008 | 09:27 PM
Quote: is it ok to scrape the metal underbody? i used to sit on eibach sportline and i would scrape the underbody just going over slightly higher bumps or a steep incline.
as long as you dont hit hard.. and dent something... i scrape alot and the tranny, exhaust, and frame are fine
Reply 0
