Splash Guard installation Help!!
Old May 1, 2008 | 08:29 PM
lov3rboy408's Avatar
i have 2006 g35 coupe sport version... i read the direction it's said i have to drill the hole... remove my tires.. i don't have all the tools to do that and i don't have the gut to drill a hole on my car.. is there any other ways to install the splash guard without drilling?.. i remember there is DIY for it.. but i can't find it..
Old May 1, 2008 | 11:14 PM
VCG35's Avatar
Sorry to say but drilling the holes are required unless you want them loose.I did mines awhile back, all you have to do is just line up the pre drilled hole on the splash guard to the hole on the car that's already there and then drill the hole.The same goes for all splash sguards.And for the back splashguards I had to take my tires off.If your not sure you could do this, you could always take it to the stealership.Good luck.
Old May 1, 2008 | 11:40 PM
silverg35guy's Avatar
Will have to drill those holes and put every screw and taps on else it will flap and come off. The tape will not hold it tight enough.. Good luck.
Old May 2, 2008 | 04:35 PM
EastBayG35's Avatar
Just did all four on my '06 yesterday. No big deal. You will need to drill holes. You can install the front ones by turning the front wheels to get room to drill, but the rear wheels will need to come off. There are clips/screws, etc. provided with the splash guards. PM me if you have questions.
Old May 2, 2008 | 07:03 PM
lniivedl's Avatar
the drilling isnt bad at all especially cuz all you do is line up the splashguard
for the fronts just turn ur wheels all the way left/right
for the rears i remembered i was able to drill one hole without taking the wheels out cuz i didnt have time and it held up decently, but eventually finished it later.
EASY install
Old May 2, 2008 | 07:04 PM
i don't have a garage to do the drilling part.. and i don't have the tools eighter.. i'm willing to pay you guy in here from bay area san jose.. if help me install it?
Old May 2, 2008 | 07:52 PM
lniivedl's Avatar
you dont REALLY need a garage..and u cant borrow a drill from a someone?
Old May 21, 2009 | 04:38 PM
skahide's Avatar
What color are the splash guards?
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
gatorglaze
Sep 10, 2015 12:03 PM
Machine Head
Sep 4, 2015 07:22 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
laksjd84
Jul 24, 2015 05:12 PM
