Re-Doing NISMO Front Mold! (need feed-back)
Old May 16, 2008 | 02:31 PM
EricIsKlumzyee's Avatar
Yep thats right.. fix the undertray problem and clea it up a bit
question..
Do we re-do it back to the original way?
tweek it a little bit.. we can change the shape of the front ducts so it looks kinda like the OEM ducting? lower it a little to line up with impul sides?
what do you guys think?
Old May 16, 2008 | 02:37 PM
Dustin@StrafeAutomotive's Avatar
Really Needs a Life
ehh.. just go back the original way..
Old May 16, 2008 | 02:49 PM
Sinister350GT's Avatar
I say lower it a little to line up with impul sides.
Can you flare it out in the cornners a little more?
Old May 16, 2008 | 02:52 PM
Really Needs a Life
just cover up both the vents. and custom make one big vent in the middle. and call it a day. and CF the whole bumper. ya, you should be good then..
Old May 16, 2008 | 02:55 PM
simpson's Avatar
keep it the way it is it would not be a nismo bumper if you change it.
Old May 16, 2008 | 02:58 PM
shabarivas's Avatar
hmm.. some photochoppers?
Old May 16, 2008 | 03:14 PM
k67p67's Avatar
Keep it as is. Double check fitment under the headlights and also the attachment point between the headlights and the grille.
Old May 16, 2008 | 03:18 PM
Nismo G's Avatar
question..
Make it a little bit wider!!! I forget who did it (sundevilJ maybe?), but he had the nismo ducts widend. Looks sick as hell!
-Sean
Old May 16, 2008 | 04:14 PM
tt awd's Avatar
Def line it up with the impul sides.
Old May 16, 2008 | 04:21 PM
K..
So widder vents
And i'll take care of the fitment stuff =)
Old May 16, 2008 | 04:37 PM
redlude97's Avatar
I would say my biggest gripe with the nismo bumper is that the openings in the vents don't match the recessed borders, shouldn't be that hard to trim them a bit larger so they look even all the way around
Old May 16, 2008 | 04:58 PM
sammy_G's Avatar
is this going to be a glass mold?
Old May 16, 2008 | 05:14 PM
IvoryGT's Avatar
I'd probably like the Nismo would a bit of flared bottom or even a small openning. like the new Vspec GTR.
Old May 16, 2008 | 06:00 PM
no poly urethane..
front bumpers & lips I do poly urethane
rest i prefer glass
- Eric
no poly urethane..
rest i prefer glass
- Eric
