05 G35 coupe..need door handle diagrams...hinge came off
Old Aug 12, 2008 | 10:00 PM
caper's Avatar
Exclamation 05 G35 coupe..need door handle diagrams...hinge came off
So i just purchased a 2005 g35 coupe and about 200 miles in the damn door handle pull off...well not quite. turns out the Dent people didnt put it back right.
if pulling on the driverside handle, the left side which only is susposed to pivit, pulls out about an inch.. possibly something is broken or maybe unscrewed..
anyone have the installtion guide?? thanks much
Old Aug 15, 2008 | 09:42 PM
Jamaica2G's Avatar
Infiniti dealer?
Back to the body shop?
Back to the people that sold you the car?
Old Aug 16, 2008 | 12:32 AM
twitch's Avatar
This might help.
Good luck!
File Type: pdf
Old Aug 16, 2008 | 12:00 PM
caper's Avatar
!!!! i thought this post was deleted but it was just moved
you guys are awesome! Thanks Twitch
and i drove out of state to get the car...id been looking for this exactly car with color and options for a year!
Old Oct 27, 2012 | 08:15 AM
junglist19's Avatar
Caper,
Were you able to fix this? Did you just have to remove the exterior handle part or did you have to remove the whole door assembly to get inside?
A similar thing just happened to my 03 Coupe after I dropped it off at the detailer but the pivot side only sticks out a half inch. I'm concerned that the crazy rain we're supposed to get on the east coast will get inside.
Thanks.
Old Nov 2, 2012 | 05:14 AM
junglist19's Avatar
Was able to find another thread about the same problem. Thread title doesn't mention the problem so it took some time to find the correct search phrase.
https://g35driver.com/forums/interio...ng-me-off.html
Basically you just need to remove the door finisher, interior panel and window. The door handle didn't need to be replaced in my case.
The exterior part of the handle needs to be reseated into the interior part. It was probably forcefully pulled from the front of the handle rather than the rear.
Not terribly difficult to fix but I'm having a bit of a difficult time reseating the window properly. i thought I had it right but I drove in the rain yesterday and some rain was dripping in. Any tips would be helpful.
Sepsis
Feb 12, 2020 02:05 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
