Removing oem grille from 06 sedan
Old Sep 24, 2008 | 12:02 PM
Mr.PotatoHead's Avatar
ive tried looking for pictures or directions for removing the oem grille of a 2006 g35 sedan... i was wondering if anything has seen this or know how to do it. any help would be appreciated.
Thanks!
Old Sep 24, 2008 | 12:52 PM
lexusk8's Avatar
Maybe you didn't look hard enough (see link below):
https://g35driver.com/forums/2463159-post10.html
Old Sep 24, 2008 | 03:12 PM
thanks bro. really appreciate your help !
Old Sep 24, 2008 | 07:32 PM
GooberGman's Avatar
I have the factory service manuals and they are junk. Your 06 will be like my 05 and while those tips will work, here's what worked for me.
After you pull the row of plastic clips on top take a long straight slot screwdriver and angle it in to the upper outer captive fastners one on each side and turn it 90 degrees to the left and thet will free them. Then angle the whole grill out from the top and you'll be able to see the long lower clip fastners on the bottom row from the top rear of the grill. Carefully push each down by hand about 1/8th inch and pull the grill out in the spot, they are easy to break and a screwdriver will do it faster then your hand. Repeat accross the bottom row until all are released and the grill is free.
When you reinstall it line up the bottom row and upper outer two and push it in in all spots and reinstall the upper clips.
Old Sep 24, 2008 | 11:26 PM
NismoGirl2001's Avatar
Thanks for this, it will come in handy this weekend
Xanthan Gum
Aug 6, 2015 10:49 AM
Scredeur4
Steering & Suspension
Jul 17, 2015 06:30 AM
