Painting my headlights soon, need advice...
Old Oct 1, 2008 | 07:52 PM
xXHotelCrazyXx's Avatar
Is it safe to bake the headlights in the oven with the ballasts and lightbulbs still installed on the headlight housing or do i need to take all that off before i bake them???
Old Oct 1, 2008 | 08:14 PM
eljoker's Avatar
no......
Old Oct 1, 2008 | 08:32 PM
patman530's Avatar
i left my ballast on, and took the bulbs out. not sure if it was a good idea to leave the ballast on, but i've baked my lights on at least 6 different occasions, and have not experienced any issues
Old Oct 1, 2008 | 08:38 PM
Dustin@StrafeAutomotive's Avatar
Really Needs a Life
i would take off ballasts and bulbs just to be sure... you neve know
Old Oct 1, 2008 | 08:45 PM
SxExCx's Avatar
Its just a few screws to remove the ballast, why risk it?
Old Oct 1, 2008 | 09:20 PM
ON's Avatar
ON
ballast should be ok. i'm would assume the temperature of the bulbs get just as hot when lit up, but just take them out, its not that hard.
Old Oct 1, 2008 | 09:30 PM
IvoryGT's Avatar
If you bake with the oven off, YES.
surest way to open them without anything getting damaged.
Pre-heat to 350.
Turn oven OFF!!!!
place headlight in for 10 minutes
Remove screws and pry apart while paying attention to the tabs, they'll stretch if you don't unclipp them.
You can do this with ballasts and bulbs...its fine, the oven doesnt heat up the parts that hot, just enough for the rubber.
Old Oct 2, 2008 | 12:14 AM
SxExCx's Avatar
the expert has spoken
Old Oct 2, 2008 | 03:14 PM
Pre-heat to 350.
Turn oven OFF!!!!
Ohhh you are the man Thanks
Old Oct 2, 2008 | 04:14 PM
GreenGoblin's Avatar
The goblin resurrection
Paul da man
Old Oct 2, 2008 | 04:19 PM
IvoryGT's Avatar
Old Oct 2, 2008 | 04:22 PM
MTG35guy's Avatar
DO IT! lol. Took me forevar to grow the b@lls to put mine in the oven. Once you do it you will be so glad you did. I took all of my ballast and stuff out, but i have read it's not needed but i was nervous. lol
Old Oct 2, 2008 | 07:25 PM
majormarcj's Avatar
Bout to do mine this weekend..gotta build up the confidence.
Old Oct 2, 2008 | 08:13 PM
patman530's Avatar
most difficult part of this whole process is taking off and putting on the bumper... the oven part is not so bad, as long as you don't overbake
Old Oct 2, 2008 | 08:16 PM
sfgr415's Avatar
We removed bulbs, ballasts, and entire wiring harness when I had my lights done. It's an additional 5-10 mins. Why risk anything?
