Grille Ques
Old Oct 12, 2008 | 12:06 AM
tsalameh512's Avatar
Grille Ques
can someone plz tell me how to take off my grille i took the 4 pins on top but it still seems to be attached i need step by step instructions thx
Old Oct 12, 2008 | 12:18 AM
ShanesG's Avatar
once you take the pins out on top it should pull right out, just give it a lil tug!
Old Oct 12, 2008 | 01:00 AM
Rhino_111's Avatar
I think it depends on the year. Mine had two plastic square screws on the far left and right that you had to turn to line up correctly for it to come out. I took a quick pic of the right side hole where it was with my iphone to show you.
And there are also 4 tabs on the bottom of the grill on the inside that you have to get press down to get it released. This is a quick pic of the center two:
A little tug on mine would have cracked and ruined it. So just take your time. Good luck
Old Oct 12, 2008 | 04:14 PM
thx ill try it tonight
Old Oct 12, 2008 | 04:36 PM
dofu's Avatar
20 Year Member
Oh hell no... your bad instructions are gonna mess up a lot of people's cars. There are have tabs all around the grille on my G...
Old Oct 12, 2008 | 04:46 PM
neight's Avatar
the coupe only has two clips (after the 4 top fasteners), one in each corner, you can try to push them out from inside but they take a little force sometimes.
Old Oct 12, 2008 | 06:13 PM
V35 Skyline GT's Avatar
6MT Coupe
^ My 06 coupe like that.
Old Oct 12, 2008 | 06:59 PM
theres a tab thing on the bottom of that that i cant get off how do i take it off?????
Old Oct 13, 2008 | 12:12 AM
Rhino_111's Avatar
Take a flashlight and look directly in there. Your arrow looks like its pointing to the square plastic screw I was talking about in my first post. You should be able to turn that slightly to line up the corners and it should slide out then do the same thing on the other side. The whole process only took like 4 minutes for me to get the grill off. Hope that helps
Picture Share
Feb 4, 2018 12:41 PM
_evilMonkey_
2nd Gen (V36) Sedan
Nov 22, 2015 06:21 PM
vQFamily
Sep 30, 2015 01:17 PM
itgogitrev
Sep 25, 2015 10:28 AM
