Passenger Power Window, Will not go back up.
Old Oct 20, 2008 | 10:57 PM
TSarra's Avatar
My passenger window on my G35 Coupe, started to acted up this weekend , it would start to go up ,when i released the power window button, the window would go back down.
Today my wife open the window and it stayed down , I was out in a small town found a Nissan Dealership , they got the window backup . Cost me $50.00. They had no parts .. and idea on what it cost to replace the power window motor . Is this a common problem on the G35 2004.
Old Oct 20, 2008 | 10:59 PM
O HELLA OEM's Avatar
yea its a common problem on 04 coupes..my driver side window sometimes doesnt close so i have to close the door real hard then it goes up lol wierd..PM rick,tony,mike@riverside infiniti...a window motor will run about $170 i think
Old Oct 23, 2008 | 12:32 PM
Tru-G's Avatar
I had both of the power windows on my 03 coupe go out on me in the first year that I owned it. Not sure if there was a recall for this issue. I would look into it if you car is out of warranty. Good luck!
Old Oct 23, 2008 | 03:35 PM
hyperlite21's Avatar
lol in that case, my window does it all the time, the little rubber things at the top get off line and it causes the window to use its safety feature it acted as if there was something stuck in your window, just realign the rubber things and bam it goes back up, they charged u 50 to do practically nothing......
this is like an every other day thing that happens to me
Old Oct 23, 2008 | 04:43 PM
crashnburn's Avatar
just punch the door right in the middle while pressing the button up... works everytime...lol im on my 3rd driver side motor and my 350z went through them as well.... ebay for 120-140 usually or 180 new
Old Oct 23, 2008 | 05:05 PM
nghiars's Avatar
just get an aftermarket window regulator.. its much cheaper than factory and will likely have leess problems.
Old Oct 29, 2008 | 04:59 PM
mubay's Avatar
i got the same problem, it goes half way up and rolls back down for some reason. Sometimes the windows won't go down, i have to hold the button then slap the door to make it work.
Does the window motor reset will fix this problem? or i need new motor?
Old Nov 3, 2008 | 04:01 AM
jayremix's Avatar
had the same problem, took it to dealership for warranty service, they had to replace the motor. It's been perfect since then
Jussaku
Interior
Jul 29, 2015 04:13 PM
will091195
Jul 27, 2015 09:19 PM
apintojr
Jul 23, 2015 10:52 AM
