Light and window remote control
Old Nov 4, 2008 | 10:54 PM
Hanoon's Avatar
Hello I'm new here and i'm so happy to see many lovers for the G35 .
I have 2 question and hope this is the place for them.
1- I'm able to hold the remote control unlock button to get the 4 windows down..Is there a way to get it up with remote?
2- The glass that covers the headlights is not clear , Im not sure if its a water condensation inside the sits in the internal side of the glass cover or its from outside.
Any advice?
Old Nov 4, 2008 | 11:09 PM
DrewTheSuit's Avatar
kp technologies makes a sensor that will allow you to use your keyfob for your windows, check the marketplace
Old Nov 5, 2008 | 11:25 AM
MidnightG35X's Avatar
If holding unlock rolls down the windows, what do you think holding lock does
Old Nov 5, 2008 | 01:01 PM
lexusk8's Avatar
Use Meguiar's Plast-X to clean and clear the headlights. That will get rid of the yellowing/hazing which resides on the lens cover.
Old Nov 5, 2008 | 02:58 PM
Hanoon's Avatar
Thank you for trying to help but I tried holding the lock and it didn't close the windows.
Thank You so much I will try it and post results here
Old Nov 15, 2008 | 12:30 AM
Hanoon's Avatar
Follow up
Update:
the headlight is much better after using 3m polish
Remote wont roll up windows without buying the module from txx technologies
Thanks to all for help
Old Nov 17, 2008 | 11:11 AM
Originally Posted by Hanoon
Update:
What G do you have? Year, sedan or coupe? Holding lock on mine raises the windows.
Old Nov 17, 2008 | 12:19 PM
IvoryGT's Avatar
^ doesn't do that for the coupe. You must be lucky
Old Nov 17, 2008 | 06:47 PM
KP Technologies makes a sensor that will allow you to roll up the windows with your keyfob
Old Nov 17, 2008 | 11:24 PM
Hanoon's Avatar
mine is the 2003 sedan..
holding lock wont roll up
Old Nov 17, 2008 | 11:47 PM
infinus's Avatar
what about sticking the key in the door and turning it and holding it there for a sec, does that do it?
Old Nov 18, 2008 | 08:27 PM
05DGx's Avatar
+1 that should have the windows roll up.
On mine, I can't just hold lock, i need to put the key in the keyhole and turn and hold the key in the lock position.
Hasanbaloch
Feb 29, 2024 08:45 PM
Muski_G
Dec 1, 2023 11:11 AM
Texasscout
Jul 24, 2015 03:43 PM
apintojr
Jul 23, 2015 10:52 AM
