Uneven hood?
Old Dec 15, 2008 | 10:31 PM
infinus's Avatar
Uneven hood?
The hood (OEM) on my drivers side sticks up above my fender while the passenger side is perfectly flush, I didn't hit anything so what could be causing it? Does anyone else have this problem?
Old Dec 15, 2008 | 10:53 PM
hyperlite21's Avatar
lets see some pictuers
Old Dec 15, 2008 | 10:57 PM
infinus's Avatar
All I have on me is my iphone, I'm at work and its dark cold and rainy so I'll have to do it when I get home
Old Dec 15, 2008 | 11:15 PM
cool, take some of the closed hood and whre the support brackets are too
Old Dec 15, 2008 | 11:18 PM
bigc's Avatar
Wings Nation
OP, do you have a strut bar?
Old Dec 15, 2008 | 11:20 PM
lol i was just about to post that cuz mine did that with my strut bar too
Old Dec 15, 2008 | 11:35 PM
infinus's Avatar
Nope No strut bar, the only thing I have even remotely in that area is the JDM battery cover and pop charger and I don't think either of those are the cause of the problem. I can push on the hood and it will go down a bit but once i let go it just pops back up.
The only place I have a gap is where it meets the drivers side fender, no uneven gaps on the passenger side or grille area.
Old Dec 15, 2008 | 11:45 PM
michdisel's Avatar
Same here...Don't know wut caused it. Everytime I open the hood driver's side pops up a lil and have 2 push it down....Can it be brackets are getting loose? Only have battery cover...no strut bar
Old Dec 15, 2008 | 11:49 PM
infinus's Avatar
I'll Have to check the brackets/bolts, But I don't really see what could have caused them to come loose, I've never messed with my hood.
Old Dec 15, 2008 | 11:51 PM
bigc's Avatar
Wings Nation
There are two rubber bump stops at the end of the hood near the ends of the grill (imagine the hood closed). You can adjust how far the hood closes by rotating these bump stops. If that doesn't work, check all the rubber gaskets along the perimeter of the engine bay to make sure they aren't in the way.
Old Dec 15, 2008 | 11:55 PM
infinus's Avatar
I'll give that a try in a little bit, thanks
Picture Share
Feb 4, 2018 12:41 PM
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
hrdwirk1
Oct 2, 2015 06:34 PM
