03 G35 Coupe dome lights dont work
Old Dec 30, 2008 | 02:01 PM
methodikal's Avatar
noob here, jz bought an 03 coupe. 3 things dont light up:
1. Dome Lights
2. Courtesy Lights
3. Ignition Key ring
Any suggestions? I already replaced the dome light bulbs and Im going to check the fuse later today to see if its busted, but if thats not the case, what is wrong and how do i fix it? I called the dealership and they were gna charge me $150 just to "diagnose" the problem. Bunch of BS if you ask me.
Old Dec 30, 2008 | 03:32 PM
jlo0109's Avatar
Disconnect your battery for a good minute or so and reconnect them back, problem solved. Next time you should try to use the search engine before you post, there were many threads regarding this issue. Best luck to you!
-Jason
Old Dec 30, 2008 | 03:41 PM
Hi-TechG35's Avatar
Actually sounds like you may have a bad body control module. Do the lights come in when you open the door? Or do you push the cover in and they come on? If that is the case then you will need to replace the unit.
Old Dec 30, 2008 | 03:51 PM
methodikal's Avatar
they dont turn on at all. hopefully this fix will work. where can i find the code for my radio? I dont wna disconnect the battery w/o knowing the code...thanks!
Old Jan 1, 2009 | 04:56 PM
methodikal's Avatar
ok disconnecting the battery for a while worked!! THanks so much for the info guys!
Mry
Mar 3, 2023 01:03 AM
mjfenix
Jul 24, 2015 05:16 PM
Lsantana757
Jul 20, 2015 09:08 AM
attarday
Jul 15, 2015 04:03 PM
