rear lights need help
Old Jan 18, 2009 | 08:33 PM
G3.5-Unit's Avatar
the bulb on the outside od the rear lights went out how do i change that bulb or do i have to take the whole light itself out?
Old Jan 18, 2009 | 08:40 PM
myroncuz's Avatar
first off, i dont know which bulb you are talking about.. secondly, if its a bulb in the taillight, youll have to remove 3 nuts from the inside of the trunk to take the light out.. one of the nuts is sorta hidden but just look for it and youll find it..
Old Jan 18, 2009 | 08:54 PM
G3.5-Unit's Avatar
its the light , on the outside of the rear light its the only one thats not an led i guess
Old Jan 18, 2009 | 09:01 PM
myroncuz's Avatar
ok then just remove the 3 nuts.. not sure about the sedans..
Old Jan 18, 2009 | 09:22 PM
erklep's Avatar
sedan or coupe? i believe youre referring to the rear sidemarker bulbs? which are 194 bulbs. you can access them by removing the trunk liner and taking out the 3 gold nuts you see and the taillight assembly will slide out
Old Jan 18, 2009 | 09:53 PM
G3.5-Unit's Avatar
yea its a coupe
Old Jan 19, 2009 | 01:49 PM
erklep's Avatar
Originally Posted by G3.5-Unit
yea its a coupe
then just follow my instructions my good man
Muski_G
Dec 1, 2023 11:11 AM
Mry
Mar 3, 2023 01:03 AM
rezendvous420
May 31, 2020 01:26 PM
mjfenix
Aug 17, 2017 05:49 AM
