Aluminum dash discoloration?
Old Jan 30, 2009 | 12:10 PM
winemaker's Avatar
Greetings. I'm posting this to see if anyone else has a similar issue. I have a 2006 G35 Coupe with aluminum dash inserts. Over the past 2+ years I have had three inserts replaced above the ash tray area because the piece turned a brown color. I have never used the ash tray. My warranty is running out soon and I'd like to see if this is happening to others.
Thanks.
Old Jan 30, 2009 | 12:24 PM
OBG3506's Avatar
+1 my 06 is doing the same thing! wonder if it is a warranty item?
Old Jan 30, 2009 | 12:26 PM
jutn35's Avatar
G35 Coupe
my dash paint is chipping in my 03, but that can be easily repainted
Old Jan 30, 2009 | 09:00 PM
Dem1K's Avatar
I had to have my aluminum dash replaced due to it turning a yellowish color. They said it's very common in our area because of the heat etc etc...so yea they replaced it for free.
Old Jan 30, 2009 | 09:30 PM
winemaker's Avatar
As I mentioned, the dash insert has been replaced under warranty three times. The dealer is telling me that they have never seen this sort of thing. I could not believe I was the only one. The warranty is running out soon and I do not want to be responsible for something a year from now when it is happening again.
Thanks to all who reply.
Old Jan 30, 2009 | 09:50 PM
Dem1K's Avatar
So what kind of answer were you looking for again? Just to see if anyone else has had the problem? Tell them that since this is a recurring problem, that if this happens again, you want it in writing that they will replace it in the future, regardless of warranty.
Old Jan 31, 2009 | 12:45 AM
gary c's Avatar
Dem's idea is good, couldn't hurt to try. Is it possible that exposure to sunlight is causing this area to deteriorate and by using a sun screen or
better yet a car cover you could solve your problem? The use of a car cover will save both your paint and interior, even my wife uses one....religously!
Gary
Old Jan 31, 2009 | 12:50 AM
Dem1K's Avatar
Yeah Gary, that's what the dealer told me, that it had to do w/ sunlight exposure
Old Jan 31, 2009 | 01:57 AM
xXHotelCrazyXx's Avatar
Take it to the dealer...
Old Mar 11, 2009 | 01:58 AM
ravi4221988's Avatar
OMG! finally someone has the same problem as me i don't get why it does that
Old Mar 11, 2009 | 02:11 AM
gary c's Avatar
Originally Posted by gary c
Is it possible that exposure to sunlight is causing this area to deteriorate and by using a sun screen or better yet a car cover you could solve your problem? The use of a car cover will save both your paint and interior, even my wife uses one....religously!
Gary
How is it possible you don't understand, had you read my post the
answer is there....over exposure to the sun! In the western states and
down south it gets really HOT inside your car even in the winter. So
if your car is left outside the sun is cooking your interior/dash. Get a
carcover, no direct sunlight....problem solved! (again)
Gary
Old Mar 11, 2009 | 02:15 AM
silverg35sport's Avatar
mine does the same thing
iDEC's Avatar
woweee. glad the sun isnt blazing in washington, it would be real annoying if my dash was changing colors ;P
Old Mar 11, 2009 | 02:20 AM
Dranom's Avatar
buy a sun visor/shade. its like 10 bucks i think at kragen/ walmart
I have the round ones that you can fold. I store it behind the passenger seat.
Work really well.Also if its Hot outside open the window a tad bit so the heat can vent out
For the dash i use 303 Aerospace Protectant.
Old Mar 12, 2009 | 06:25 PM
gnu5's Avatar
same thing happen to me, how do u convince them that it should be replaced under warranty.....service adviser sounds like a stubborn ***...
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
Picture Share
Feb 4, 2018 12:41 PM
g.spot
May 9, 2016 10:54 PM
