Full LED Taillights
Old Jun 17, 2004 | 11:59 AM
SteveJohnson's Avatar
Full LED Taillights
I'm producing a taillight kit to upgrade the blinkers to full LED instead of the incandescent bulb that is currently in there. I'm wondring if anybody else feels like the taillights should be full LED instead of half/half like they are now. I love the look of the brake lights, but why didn't they make the blinkers the same?? What I'm thinking about doing is creating a taillight set that has an animated pattern of lights chasing to the outside point of the blinker housing. I think this would look awesome.. But I'm looking for public oppinion to tell me if I'm off my rocker and if this is silly looking!
Old Jun 17, 2004 | 12:15 PM
DragonGcoupe's Avatar
Re: Full LED Taillights
I'm sure it would look great, but I must say the taillights look pretty damn hot as it is. Not many cars have taillights that look so cool at night.
Black / Black 2004 GcoupeMT. Premium. Splash Guardz.
Old Jun 17, 2004 | 01:13 PM
G35Tuning's Avatar
NO cars have tailights that look this cool at night...I know there's hotter more expensive rides out there but nothing beats these tailights...Atleast not in my opinion...But upgraded blinkers may look nice..
Old Jun 17, 2004 | 01:34 PM
That's what I'm thinking too.. These taillights look awesome at night. I think a suprise LED light filling to the right when the blinker was on would be the icing on the cake. I'm going to produce a couple and put them on my G. I've got to get some oppinion on them cause I think it would rock to not only have full LED taillights but an animated pointing blink would kick ***. How many cars have that?? :-)
Old Jun 17, 2004 | 02:00 PM
G35Tuning's Avatar
Give it a shot and post some pics when your done...I'm sure if they look good plenty of people will be interested...
Old Jun 17, 2004 | 02:04 PM
G35sedan03's Avatar
it does sound pretty good, at least in theory. I would probably support that too. Definitely keep us posted.
03.5 BS, 6MT, premium, 19" Kaizer wheels, Skyline badges, PIAA HID upgrade, Racing pedals, clear lenses, 35% tint, 7-wire ground, TEIN basics, side mirror blinkers
Old Jun 17, 2004 | 05:52 PM
RazorX35's Avatar
I think it would look cool if the blinkers were like the new l.e.d. lights on the new Range Rover. With the blinker in the middle and the brake light surrounding it. Just an opinion.
<font color=blue>2003 Caribbean Blue Coupe
6MT Prem, Aero, Nav.</font color=blue>[img]/w3timages/icons/cool.gif[/img]
Old Jun 18, 2004 | 04:33 AM
Sukairain's Avatar
I think I just found what I have been looking for..... :grin: Can somebody with some electrical experience teach me how to regulate the voltage of the LED do they can be run off the stock turn signal wires?
Old Jun 18, 2004 | 11:36 AM
It kinda depends on the type of LEDs you have and the load that they will pull. Are they wired in parralell or series? Probably they will run off of the 12 volts that you supply through the blinker signal, but the brightness might not be adequate. Or perhaps too bright if they're 9 volt LEDs in which case you'll end up burning them out. You should also consider the way in which you mount them. These enclosures are freken tanks. I'm having a hard time even engineering how to theoretically take one apart and put it back together again.
Old Jun 21, 2004 | 02:02 PM
EustaqJA's Avatar
If you guys figure this out, I'M STANDING BY TO BUY SOME!
Tail lights shouls be all LEDs. If you get this to work, let us know!
Godspeed gentleman.
Old Jun 21, 2004 | 02:42 PM
turbomaxima's Avatar
Man with green rock in Vortech
mmm.. love led tails, a good friend of mine and i made these for my other car awhile back:
Comparison:
good luck with your project.
Old Jun 23, 2004 | 11:48 AM
irony's Avatar
I'm interested
Old Jun 25, 2004 | 08:55 AM
OvaYahead's Avatar
that's cool. I'm down to be a guinee pig. I'm just wondering about the wiring though.
Where is the power wire going to splice into? If you connect it to the running won't it dim the rest of the LED's? This is the only reason why I haven't messed with the rear lights yet. Should a capacitor be used ?
Old Jul 10, 2004 | 04:46 AM
Sukairain's Avatar
Alright, I am kind of stuck since my car is on the other end of the continent right now. Can someone post a picture of the coupe tail lamp assembly from the back side. Specificly the turn signal socket without the light bulb in there.
If I recall correctly, the opening to the turn signal housing is quite small. I am not sure I would be able to fit these circular LED board in there.
Secondly, what I am planning to do is NOT to replace turn signals with LEDs. I am try to tie in the circular pattern LED to the running light/brake light and have it function together like the other LED lamps. The turn signal bulb base would go though the center of the hole and blink as usual.
In the mean time, I need to find the right resistor before I blow my fuse out. Update when I get back to Boston to finish the work.
Old Jul 14, 2004 | 03:40 PM
hector2112's Avatar
You want to be carefull when messing with the taillights. I had a diaode blow on mine and the care ran like crap. so you want to be carefull when doing this
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
suby01
Not G35 Related
May 25, 2016 03:07 PM
DEMoLITIoN
Apr 20, 2016 06:57 PM
Gabe83714
Oct 6, 2015 06:40 AM
