will an 06/07 headlight kit fit on an 03
i got a 03 coupe and ive never changed my bulbs and my lights are lookin extra dim right now but it seems to me the 06/07 headlight are extra bright so i was thinkin of swappin them out. or i'll take some suggestions on what type of headlights or bulbs i should get.
Projectors rule compared to the 03 setup. If you need a guide as to what replacement bulbs are needed in the 06 headlights go to http://www.sylvania.com/ConsumerProd...lacementGuide/ this is what i used. Also, you can use the same ballasts that your car already has. If you have any questions let me know.
i believe the 03-05 use the same bulb the d2r but 06 uses the d2s bulb which are for the projectors
the 03-05 have the d2r bulbs and the 06+ projectors have the d2s bulbs. When switching the headlamps makes sure you switch the bulb also. If not the projectors with the d2r (03-05) bulbs will be bright as fu<k to the oncoming traffic which will make it dangerous for others on the road. the 06 projectors are def look better tho :thumbsup:
bTanz
Oct 15, 2015 02:31 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
