Small windows on rear doors loose?
Old Mar 11, 2009 | 10:03 PM
dhl's Avatar
dhl
Anyone have the issue where the small windows on the rear doors are loose? I noticed that I was getting alot of road noise from the rear passenger side yesterday when driving through the rain. So today I checked around and couldn't find anything until I touched th small windows and noticed that it moved a lot and felt loose, I checked the rear driver side small window and it had some play, but much less. I'm going to have it checked out tomorrow as I already have an appointment at the dealership for the following:
1. Creaking sound from rear driverside door (probably the window regulator bolt TSB issue)
2. Clicking from the passenger side tires (probably the clicking TSB issue)
3. Creaking from front of car when going slowly into my drive way which has a high entry lip (compression rod TSB)
4. Homelink mirror button has paint worn off.
5. Loose small rear windows... wonder if they will cover this under the 4yr/60k mile warranty.
My G35x basic warranty expires 4/29, so I'm getting all this cleared up now.
Old Mar 11, 2009 | 11:39 PM
TheTick's Avatar
I also just noticed a lot of wind noise only at 75+mph coming from that area. I had a friend sit back there and confirm that it was the small rear side window. Let us know what you find out.
Old Mar 12, 2009 | 09:35 AM
dhl's Avatar
dhl
Brought it in this morning and the dealer was being wishy washy about items # 1 - 3 being covered under warranty as well as the TSBs. Shouldn't those 3 items be no charge items? I'll update as soon as I hear from them on their "estimate".
Old Mar 12, 2009 | 01:29 PM
dhl's Avatar
dhl
1. Creaking sound from rear driverside door (probably the window regulator bolt TSB issue) - Fixed free under TSB/warranty.
2. Clicking from the passenger side tires (probably the clicking TSB issue) - They said it was from aftermarket brakes, and not coming from the area that the TSB covers.3. Creaking from front of car when going slowly into my drive way which has a high entry lip (compression rod TSB) - Replaced compressions rods for free under TSB/warranty..
4. Homelink mirror button has paint worn off. - Forgot to ask them to take care of this.5. Loose small rear windows... wonder if they will cover this under the 4yr/60k mile warranty. They said that it is normal and within spec?
Old Mar 12, 2009 | 05:11 PM
ckg35's Avatar
I doubt that this would be covered under warranty as it's normal wear and tear....but worth a try!
Old Mar 12, 2009 | 06:02 PM
dhl's Avatar
dhl
They do have a TSB for it.
ITB08-026
INFINITI; HOMELINK® INSIDE MIRROR BUTTONS’
PAINT PEELING / FADING / CHIPPED
One or more of the Homelink® inside mirror buttons’ paint has faded, peeled, or chipped.
Old Mar 12, 2009 | 07:16 PM
acr's Avatar
acr
I think my G35x also suffers from issues 1-3. Where did you find a list of these TSBs? I want to print them out and bring them to the dealership to get everything taken care of before the warranty is up. Also, does the warranty for all 05 Infinitis end 4/29? I bought my G used so I don't know when it was originally sold.
Old Mar 12, 2009 | 07:25 PM
dhl's Avatar
dhl
My car's in service date is 4/30/2005 so it expires 4 years later on 4/29/2009. You can find the TSB's at http://x.infinitihelp.com/forum/loca...s.php?catid=71
mike730
Jan 12, 2018 04:25 PM
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
atk08
Jul 30, 2015 03:12 PM
will091195
Jul 27, 2015 09:19 PM
apintojr
Jul 23, 2015 10:52 AM
