NRG hood dampers
Old Jul 8, 2009 | 02:26 PM
tblazing's Avatar
NRG hood dampers
I just installed my NRG hood dampers and I noticed some rubbing between the fender and the hood on the passenger side is there any way to fix it?
Old Jul 8, 2009 | 03:32 PM
DiGil's Avatar
Is it right on the corner of the fender up near the windshield? If so, I don't think it's a problem with the hood damper, I think it's the hood hinges. I just had this problem on my Coupe. Apparently our hood hinges need to be periodically lubed, otherwise the friction will cause them to bind, which in turn will cause them to bend and finally cause the hood to rub on the fender.
Old Jul 8, 2009 | 03:36 PM
tblazing's Avatar
^^^ thats exactly where it is rubbing...so will lubing the hinges fix the problem
Old Jul 8, 2009 | 05:06 PM
Swivel's Avatar
Moderator
Yes, if they are not bent or at least not too much. And use a good lithium spray grease, not WD40.
Picture Share
Feb 4, 2018 12:41 PM
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
hrdwirk1
Oct 2, 2015 06:34 PM
