Passenger Side Door lock/Window panel
Old Jun 22, 2010 | 05:28 PM
conq's Avatar
Anyone have issue with the window/door lock panel on the passenger side? I had the issue intermittently over the years but now its completely dead. I know its not the door lock actuator because i can lock from driver side. The window motor rolldown is also dead on the pass side which could just be that motor, but its weird for the lock to not work too.
I opened up the door to check for loose connections and everything is fine. I cant really test the window motor without taking it off, i guess i can hook up a multimeter to see if its getting any juice, but i dont think so.
I did replace the driver side window motor a few months ago because it died.
Old Jun 22, 2010 | 05:44 PM
conq's Avatar
Holy shi%!T
Never mind after a search, this was fixed by the famous "open close door while holding up/down window switch" technique.
Seriously WTF infiniti/nissan.
Old Jun 27, 2010 | 04:21 PM
conq's Avatar
Seems like that only worked for a little time. not sure whats wrong going ot have to break out the multimeter to find the culprit.
xluke
Jul 30, 2016 01:48 PM
tiguy99
Mar 1, 2016 11:42 AM
ev_g35
Interior
Aug 14, 2015 02:05 PM
emorehs
Jul 17, 2015 09:45 AM
