PIAA xtreme white
Old Oct 6, 2004 | 03:01 PM
Gaaaar's Avatar
Re: PIAA xtreme white
Ok i just got the lights the PIAA xtreme white lights for my clear corners. How do i install this??
THis is what i got: http://www.importperformancewarehous...l?v=1&pid=1765
Any help on how to install this would be appreciated. Thank You.
Old Oct 6, 2004 | 04:15 PM
takuyaah's Avatar
i didn't use latex gloves..just make sure you don't touch the bulbs part.....i think its ok if you touch the metal part at the end of the bulb..you should be ok...on the other hand..i need to warn everyone to be careful when you install the clearance strip light.....the bulbs are not in very tight so be careful not to drop them in the strip...
04.5 black/willow 5at coupe | premium package
clear corners | mtec fog/clearance/corners
alumium pedals | black emblems | 20/35 tints
Old Oct 6, 2004 | 04:30 PM
roneski's Avatar
Devil's Advocate
You just pop off the clear corners, remove the bulb receptacle from the clear corner, pull out the old bulb and push the new one in. Then put it all back together.
Avoid touching the bulb with your bare hands though because it can shorten the life of the bulb.
"America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves."
-- Abraham Lincoln
Old Oct 7, 2004 | 06:42 PM
Premier's Avatar
If I get done with the tint on your car ahead of schedule, I'll help you put them in. See you tomorrow!
Certified Window Tint & Detailing Specialist
Premier Paintless Dent Repair
3M / VentureShield Paint Protection Film Dealer
Madico Window Film Dealer
2003 AT Sedan / 2004 6MT Coupe
Picture Share
Feb 4, 2018 12:41 PM
Albanian122
NorthEast
Sep 28, 2015 03:03 PM
twentyeggs
Sep 11, 2015 03:58 PM
