PIAA xtreme white
PIAA xtreme white
Im sorry for being a newb about this, but i was wondering if the installation of these lights are hard for the clear corners and the license plate. Because i have absolutely no skills at all as to how to wire things and if this is just a simple exchanging light bulbs than ill get it, if not then i would need to know how hard it is to install before i purchse it. Please let me know how to install them and if its hard or not. THank You.
Re: PIAA xtreme white
I dont know how to post links but are these it???
http://www.xtremewhite.com/ORD-Light...52-1-1-1-1.cfm
That looks like the right one. I ordered from here, it's a bit cheaper.
http://www.importperformancewarehous...l?v=1&pid=1765
I also replaced the fog/high beams with these.
http://www.importperformancewarehous...l?v=1&pid=1727
roneski so basically i just have to purchase one right? since its a twin pack.. I kno the clear corners are really easy, i have them already but im worried about changing the bulb is there any wiring involved? or its just basically takin a bulb out and replacing it with the new one??
Heres a shot of my car with the Piaa Extreme whites in both clear corner and clearance strip, and my MTEC H4 Super White fog/high bulbs......
The owners manual explains how to change the bulb on the corner markers.....Its very easy and the clearance strip bulb comes out the same way, however, It requires a little more work....if you change them, might as well do the fog/high bulbs while your at it.....
look here this will give you the information to change the clearance bulbs and fog/highs.......
![](https://g35driver.com/forums/attatchments/342417-sigpic913.jpg)
04 cpe JDM clear corners/Piaa's/MTEC H4 Super White fog/highs
