Boser hood: Need help
Old Aug 27, 2010 | 02:32 AM
LaserRedG35VS's Avatar
Hey guys, plan on doing this as my lip kit gets redone- the picture below is how i want the hood to go over headlights. I cant find an eyelid that matches that design. Having the pieces pre-cut and then attached to hood would be so much easier for the job. Anyone know where i can find an eyelid like that??
Old Aug 27, 2010 | 02:48 AM
Dustin@StrafeAutomotive's Avatar
Really Needs a Life
No you would have to make a custom one out of a current design of eyelid. Mold it. Then shave it accordingly for clearance. Good luck!
Old Aug 27, 2010 | 03:19 AM
I'll ask the guy working on it if it would be easier to start from a current eyelid design. I heard you can get a big metal piece and attach to hood from bottom and cut it out to go over headlights. Sounds like the eyelid process would be easier though.
Old Aug 28, 2010 | 11:31 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
The problem is, you have to make a matching indentation in the headlight, otherwise it's not going to be flushed and look a lot more gay than that photoshop.
Old Aug 28, 2010 | 12:00 PM
Calvin's Avatar
Overglorified Altima
This.
Old Aug 28, 2010 | 04:34 PM
dofu's Avatar
20 Year Member
You can always have a vinyl piece on your headlight as a buffer for the piece welded to the hood if you feel you really need to get it that flush...
I wouldn't suggest using a thin piece of metal. But it's going to take more than just a little welding and sanding since the piece has to go over the headlight and you want the hood to be flush. All in all, it shouldn't be too hard to make.
Old Aug 30, 2010 | 04:15 PM
G2FLIP4's Avatar
everything
Find someone with an english wheel. They can form the filler piece to the curve of the headlight. Roll a bead on the edge for you and then just grind and weld it to the hood
Frankly I think boser hoods and stick on eyelids everyone does looks super ghey, but props on custom work if you go that route, Ive done my fair share of metalwork and bodywork and know how hard it can be when making parts from scratch.
Old Aug 31, 2010 | 02:32 AM
I think it will look fine going over the headlights without indenting them b/c eyelids don't look that bad the only thing is the gap between the hood. If anyone can post pics of eyelids on G (from a good angle to see how much higher they sit than the hood-that would be great.) Thin piece of metal should do the job. My only real problem is the design of this piece. I like the way the pic above looks but HomieG35 might have a point, so here are the other two pics of boser hood. Which do you guys suggest?
geethreefeev
Sep 23, 2009 11:09 PM
Blue_Batmobile
Picture Share
69
May 4, 2008 04:56 PM
