Painting Vinyl?
Old Oct 8, 2010 | 01:42 PM
sekars2012's Avatar
Paint is either oil or water based. look on the cans. If it says thin the paint and wash brushes with water then it is water based. If it says thin the paint and clean brushes with white spirit, then it is oil-based. Most of the time you can mix two water-based paints together or two oil-based paints together, but you can never mix oil and water paints. (though you can paint with them on top of each other).
ac orifice tube
lanzarote island
Old Oct 9, 2010 | 04:01 PM
TIAN's Avatar
Hold The Line
I didn't get that either. Didn't really answer your question. I don't think you could without it peeling. Unless the primer will stick which I doubt as the surface of vinyl is a gloss smooth type surface unless you can lightly sand it. Wouldn't know.
Old Oct 9, 2010 | 07:46 PM
the04coupe's Avatar
nope any flex and it will crack and peel
Old Oct 11, 2010 | 10:40 AM
G2FLIP4's Avatar
everything
Youre not searching hard enuf... they make vinyl in pretty much every color imaginable... They can even make it in pantone colors. If all else fails talk to a local sign/graphics company. The place I used to work for had a UV printer and we could print whatever we could imagine on adhesive backed vinyl. Graphics or just solid colors, then we'd throw it on the CNC router and cut them out.
Picture Share
Feb 4, 2018 12:41 PM
DRG35R
Jan 31, 2016 07:14 AM
atomevolution
Engine - Exhaust
Oct 12, 2015 01:00 PM
