Bulb replacement instructions
Old Oct 17, 2004 | 04:00 PM
jcottrell's Avatar
Can some please post or point me to some instrucions for replacing the HID bulbs with 6000K bulbs, Clearance strip bulbs with PIAA LED bulbs, and corner bulbs with PIAA LED bulbs. To my understanding, there is some wiring that needs to be done for the LED replacements. Thanks.
Old Oct 18, 2004 | 11:20 AM
SFLG35's Avatar
FGC President
Re: Bulb replacement instructions
Lights DIY there you go dude. that will get you the fogs. the HIDs are just above the fogs, and the clearance lights are on the side up top. shouldnt miss them.
on the HIDs you take the back cover off, then you will see a square metal connector on the back of the bulb(it has a metal braided wire goin to it) turn it to the right (maybe left dont remember) and then pull it off. after that there are 2 of the spring clips like in the fog light that you have to release and the bulb will pop out.
becareful not to touch the bulb with your hands or you will ruin it.
Daniel
screw the GTC's. Maya RT5's now!!!
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
JG_G35
Lights
21
Sep 14, 2015 02:00 AM
EasySausage
Jul 20, 2015 03:56 PM
attarday
Jul 15, 2015 04:03 PM
