Interior light replacement
Old Oct 22, 2004 | 04:57 PM
DeMoNWaReS's Avatar
I need help... I got this list which might help all of you who are interested in changing stock lights
2004 INFINITI G35 (With HID (high intensity discharge) headlamps)
Low beam headlamp
HID-D2R
High beam headlamp
9003
9003ST Silverstar High Performance Halogen Upgrade: The Look of HID: Whitest, Brightest
9003XV XtraVision Halogen Upgrade: Up to 30% Brighter
9003CB Cool Blue Halogen Upgrade: White Hot; Super Cool; 100% Street Legal
Parking light
168
Front turn signal
7440
Rear turn signal
7440
Tail light
LED
Stop light
LED
High mount stop light
LED
Fog/Driving light
9003
License plate
168
Back up light
921
921LL Long Life Upgrade: Up to twice the life of the standard lamp
Front sidemarker
194
194LL Long Life Upgrade: Up to twice the life of the standard lamp
Rear sidemarker
194
Map light
DE3175
Dome light
DE3175
Step/Courtesy light
DE3022
Trunk/Cargo area
158
_______________________
I want to replace all my interior lights and trunk. I suppose they are called:
Map light
DE3175
Dome light
DE3175
Step/Courtesy light
DE3022
Trunk/Cargo area
158
Which are the MAP lights and which are the DOME lights?
I want to change them for PIAA's Xtreme White. Can someone tell me how many of each type of bulb i need to change all interior lights (including glove box) and the trunk? I would be rateful if you can tell me the exact part number and/or give link to where to buy.
Old Oct 22, 2004 | 05:21 PM
DeMoNWaReS's Avatar
Re: Interior light replacement
I just got back from my car, and these are the lights I found which I would like to replace.
Trunk = 1 light
Door Sills = 2 lights (one in each side)
Glove = 1 light (I might not even change this cuz its impossible as far as I know to change this one easily)
Vanity Mirror = 1 (this one is even worse than glove, I took the white plastic covering to see the bulb, and it seems it is soldered)
As to what map and dome lights are, I dont know. I suppose Dome are the interior lights and Map are the ones that lit the dashboard?
Old Oct 13, 2009 | 12:41 PM
RicoG35x's Avatar
Hey Bud.. the DOME lights are the ones over the rear doors on the sedan... the MAP lights are the ones directly over the console.. all of them on the headliner... same bulb DE3175.
Old Jun 11, 2010 | 03:15 PM
RicoG35x's Avatar
UPDATE:
I just replaced the lower glove box lamp on my 04 G35x sedan with this offering from VLEDS... direct fit, great illumination with a clean white light! It fit perfectly into the bulb socket... no muss.. no fuss.. took like 5 minutes to do it!
http://www.v-leds.com/Interior-LED/G...-p6622390.html
it was $9 for a pair.. so you have a spare. check it out if you're interested.. great turn around time... 2 days from Washington State to Ohio. (USPS)
I'll have pics later today...<!-- google_ad_section_end --> <!-- / message --><!-- sig -->
Old Jun 16, 2010 | 12:06 AM
walshtj's Avatar
Yeah changed my map lights and its real nice and bright.
Old Feb 19, 2011 | 06:19 PM
lanks89's Avatar
Anybody change the ignition key ring light?
Old Mar 6, 2011 | 03:04 AM
EDGAR's Avatar
I Replaced all my lighting to LEDs including the key ring!
Old Mar 13, 2011 | 11:14 PM
EvoBeast's Avatar
i was looking through v-led. and there is so many styles of LED lights. i was looking at replacing the courtesy door light, dome light, or map light, and the license plate light. and possibly the light in my headlight (the one that is in that strip)
but with all the choices of light, how do i know what fits. for example, i was looking at the license plate lights, and there apparently 168. lookingn through, there are ones with one LED, 6angled LED and a few other different ones.
what am i looking for
Old Mar 13, 2011 | 11:49 PM
PERKS11's Avatar
hadnt thought about LEDs in key ring...im gonna have to go check that out now...
Old Jul 30, 2011 | 01:14 AM
Speg80's Avatar
So how do you change the glove box light
Old Aug 1, 2011 | 02:02 PM
lanks89's Avatar
What style of light did you use for the key ring?
Old Aug 2, 2011 | 09:38 AM
Speg80's Avatar
The glove box must be removed to change the bulb , four screws and then pull forward to release the platic clips, I would change the bulb in the upper box at the same time you can access it easily with the glove box off.
Old Aug 2, 2011 | 11:05 AM
RicoG35x's Avatar
I agree.. since it's such an undertaking to get the glove box stripped down to get to the light.. you'll have most of the stuff out to get to the upper glove box... might as well...
I used these leds from VLEDS.. work great!
Upper: http://www.v-leds.com/Interior-LED-B...-p6298403.html
Lower: http://www.v-leds.com/Interior-LED-B...-p6622390.html
the upper has two side-firing leds and a top firing led (3 total) so it fills the compartment better since it socket side mounts in the glove box.
mike730
Jan 12, 2018 04:25 PM
s8n
Jul 31, 2015 01:37 AM
s8n
Jul 30, 2015 04:47 AM
Jadenkid22
Jul 14, 2015 12:33 AM
