Plasti dip diffuser
Old Dec 7, 2010 | 12:24 AM
erklep's Avatar
Originally Posted by Smitty50
Ya caught me lol
diffuser looks nice btw. and i have to add to the above advice.... if you pull the tape off while its still wet, youll get a nice clean line. i had to spray the rubber trim at the bottom of my window due to an egg eating away at the finish and i taped off, sprayed, and removed the tape right away and it came out great
Old Dec 7, 2010 | 12:26 AM
Smitty50's Avatar
Thank you very much, the effort to make the diffuser was def a good reward. I'll tape it up and respray sometime this week and peel it off right away.
Old Dec 7, 2010 | 12:48 AM
kennymo's Avatar
when i did my window trim before i pulled the tape off i took a razor blade and cut all the way around the edge of the window trim so it would seperate the tape from the plasti dip that i wanted to stay
Old Dec 7, 2010 | 01:06 AM
sTeadFasT96's Avatar
Yeah mine turned out exactly like yours, I just went back and instead of doing the separation at the crevice, I did it at the edge where the bumper begins to dip into the crevice (if that makes sense?)
Mask everything but the little crevice and spray it over, that's what I did, you can't really tell it's messed up without getting MAD close.
Old Dec 7, 2010 | 02:10 PM
zoop425's Avatar
Whats up man, I think Im the one you got the idea from.. Yeah to get a clean line, do what you did then tape the strait line back on after, go over the spots with a heavy coat to replicate 2-3 coats and peel off the tape while its still wet.
Old Dec 7, 2010 | 03:53 PM
WhiteonWheat's Avatar
Great work!!
-WoW
Old Dec 15, 2010 | 09:32 AM
stabadus's Avatar
For all those people suggesting to take the tape off while the plasti dip is still wet:
Is this tip for the last coat or do this after each coating? That seems like a lot of work..
Also, has anyone used plasti dip as primer then painted over it with glossy black for the rear diffuser? I know some people have done this for rims and it comes out glossy as oposed to the standard plasti dip finish - matte. Any pics of glossy diffuser? Preferences?
Old Dec 15, 2010 | 11:29 AM
erklep's Avatar
has to be done for each coat if youre applying multiple coats. the reason for pulling the tape while its wet is so it doesnt form a rubber layer from the vehicle to the tape. either pull it after each layer or score it with a razor before you pull the tape after the final coat.
Old Dec 15, 2010 | 12:14 PM
stabadus's Avatar
Scoring it with a razor before pulling the tape after the final coat seems more practical, I'm pretty sure I'd get the wet plasti dip everywhere.
Thanks
Picture Share
Feb 4, 2018 12:41 PM
Kelvin Style006
May 23, 2016 03:47 AM
_evilMonkey_
2nd Gen (V36) Sedan
Nov 22, 2015 06:21 PM
