window problems
Old Dec 22, 2010 | 03:46 AM
aaron_boost's Avatar
window problems
04 Sedan
on the drivers side master window switch the passenger window will not roll up or down. no clicking can be heard. if i use the passenger side switch it works, rolls up and down. i have already done the window reset procedure, but still the drivers side switch wont respond.
>before i purchase a new master switch, does anyone have any other suggestions on what the problem is?
Old Dec 22, 2010 | 10:25 AM
geew1z's Avatar
I personally would find out which wires in the door control the passenger window and jump them to see if it responds. If it does, then its just the switch
Old Dec 22, 2010 | 09:15 PM
G35pwrd's Avatar
My driver rear window did not work from the front driver switch. Got a used one on ebay, fixed. Check car-parts.com
Old Dec 24, 2010 | 12:54 AM
NFSP G35's Avatar
? = 2B || !2B
Our window controls are a little more complicated than that.
Old Dec 24, 2010 | 02:59 AM
ok cool ill check it out.
Old Dec 24, 2010 | 03:03 AM
thanks for the suggestion, but the window motor does not stick or have the "go up then down" problem. as stated the window motor works fine and moves freely with the passenger window switch. only when i use the drivers side master switch does it not work. this leads me to believe that the driver master switch and/or relay may be faulty.
Old Dec 24, 2010 | 03:07 AM
JBF's Avatar
JBF
was it necessary to make two threads about this?
mike730
Jan 12, 2018 04:25 PM
leo38cheng
Nov 12, 2015 06:49 PM
cmesidewayz
Sep 29, 2015 09:28 PM
gatorglaze
Sep 10, 2015 12:03 PM
Jnm07
Sep 5, 2015 01:16 AM
