Coupe Dual L.E.D. tail lights
Old Feb 21, 2011 | 11:10 AM
Chuck D's Avatar
I so want this on my G
Old Feb 22, 2011 | 12:55 AM
Majiks's Avatar
In for the pix of the finished product... i was in the old thread also
Old Feb 22, 2011 | 07:22 PM
Shiftd's Avatar
wow cant wait for the pics!
Old Feb 22, 2011 | 07:25 PM
CITIM1KE's Avatar
sick mod in for final pics
Old Feb 23, 2011 | 05:12 PM
same olg's Avatar
Any update???
Old Feb 23, 2011 | 09:20 PM
G2FLIP4's Avatar
everything
Originally Posted by same olg
Any update???
Theyre being wired right now. Working out all the bugs. He'll ship them back to me once he's done.
Old Feb 24, 2011 | 02:12 AM
the04coupe's Avatar
I got 1 tail is fully built and finishing up on the last then shipping back to gflip so he can reinstall his lenses . I will post pics and a video in a little while . I recently got a new camera and kind of od'ed on pictures so its gonna take me a little while to upload . All 18mp 1080p quality . I document the build from start to finish so you guys can see the quality and amount of work that goes into my build . It easily exceeds oem quality .
Old Feb 24, 2011 | 03:24 AM
Majiks's Avatar
cant wait to see all the pics and the finished product
Old Feb 24, 2011 | 04:07 AM
VictoriousG's Avatar
In for teh finished product
Old Feb 24, 2011 | 09:51 AM
same olg's Avatar
Sickkk, Let me tell you i know Chris, and his work is top notch the time he puts in to doing something and the quality is unbelievable.
Old Feb 24, 2011 | 08:26 PM
the04coupe's Avatar
Exclamation
Here we go . I tried to document most stuff in the pics . There is a lot of work before whats in the pics in designing and building the PCBs .Pics start at the end of pcb fabrication to finish . My Illumenator and DFC modules are standard boards we make that are used on a lot of my retrofits . Leds used are genuine LEDs (same as factory ) and come in BIN code matched factory tubes . Bin matching from the factory means every led is tested and sorted to have the exact same hue,brightness,voltage and current . No LED is different by even the slightest margin unlike normal LEDs sold most LEDs which are sold in bags of unmatched LEDs . Leds also run at 70ma typ rather than the majority of leds that only run at 20ma . The custom led boards im also using 2oz of copper which add to reliablility by dissapating more heat . All boards are plug and play . The illumenator pulse width modulated the Leds to control marker brightness while also voltage regulating the LEDs to 12v even when the car is putting out 14+ V . Letting the LEDs see 14+v is the biggest contributor to failing LEDs . The DFC module is working in conjuction with the Illumenator letting the LED rings work as turn signals thus disabling the marker or brake function when turn signal is active . Also as you can see in the pics i replaced the factory LED PCB with my own . I could have used the factory but wanted to be sure they matched in everyway . Also because the oem board circuit is less reliable than the new one because of the parallel wiring . Lastly as you can see i needed to design 2 different inner ring because the factory mounting spots are different between the 03-05 and 06-07 .
Pics in order somewhat .Videos at the bottom .Taken with canon rebel t2i .
Old Feb 24, 2011 | 08:28 PM
saywat?'s Avatar
man clearcorners.com aint got nothing on this guy lol
Old Feb 24, 2011 | 08:30 PM
the04coupe's Avatar
Pics are in previous post . Heres the videos . They are in 1080p hd
Final video
test videos
Old Feb 24, 2011 | 08:34 PM
G2FLIP4's Avatar
everything
WOW... JUST WOW!!!
Cant wait to get them back and installed. AMAZING WORK!
The red of the 2 rings look a little different but I think its cuz the chrome is a little different on the parts I had plated, should look exactly the same once I put the red lens back on.
Also look more uniform once I get the clear domes in the center of all 4 rings
Old Feb 24, 2011 | 08:38 PM
  #30
TIAN's Avatar
Hold The Line
Very nice. Those look like they're OEM! Great work fellas!
