Coupe Dual L.E.D. tail lights
Old Mar 4, 2011 | 02:29 AM
  #61
nissandrifter32's Avatar
pretty sickkkk
Old Mar 4, 2011 | 11:30 AM
  #62
teahead's Avatar
My plans are the same. Totally disable the inner, rectangle array of LEDs, and have painted the whole chrome housing (except the chrome LED round shrouds and barrels).
Still considering whether to go with sequential turn signals...
the04coupe, got any videos of this?
Old Mar 4, 2011 | 05:18 PM
  #63
the04coupe's Avatar
Im not sure if its possible to do the sequential with this style . if i did it more than likely cant be plug n play .
Old Mar 8, 2011 | 07:03 PM
  #64
G2FLIP4's Avatar
everything
Been in Dallas for the past 6 days, leaving for Chicago in about 30 minutes....
put the light back in the car and just taped the red lens for now for pics
Old Mar 8, 2011 | 07:35 PM
  #65
tygastyle80's Avatar
sexy
Old Mar 8, 2011 | 07:55 PM
  #66
VictoriousG's Avatar
noice!
Old Mar 8, 2011 | 09:31 PM
  #67
Chuck D's Avatar
So sick!
Old Mar 8, 2011 | 10:17 PM
  #68
the04coupe's Avatar
Looks f'in sick installed expecially with the blacked out body .
Old Mar 8, 2011 | 10:44 PM
  #69
jookyshank's Avatar
I haz hugz to givez
Good work you two! now start the mass production line!!
Old Mar 9, 2011 | 04:01 AM
  #70
Majiks's Avatar
Mass produce itt :d
Old Mar 9, 2011 | 04:39 AM
  #71
My Key's Avatar
siiiick
Old Mar 9, 2011 | 09:45 AM
  #72
HavokGT's Avatar
Tommy likey....
I want em.
Old Mar 9, 2011 | 10:32 AM
  #73
ConradoR's Avatar
Since I have been commenting and following this project since this was still in the pre-design phase, I feel like it's okay for me to point out the 80-pound gorilla in the room.
They are very close but still don't match OEM. Since the ring housing design is the same as the oem ring housing design, and the depth of each led insert was kept the same as the original ring, the only other variable to be considered is the difference in chroming.
The solution for someone who really wants PERFECT rings and is willing to shell out the extra cash would be to rechrome the factory led ring, so both oem and new ring housings have the same chrome finish done, thus reflecting the leds the same way. I believe then, the leds will finally match perfectly, and this fight to produce perfect dual ring tails will finally be beat.
Good job to both the04Coupe and G2Flip4, you guys are really stepping up the game with this project.
Old Mar 9, 2011 | 04:07 PM
  #74
HavokGT's Avatar
^ +1
Old Mar 9, 2011 | 05:17 PM
  #75
teahead's Avatar
I don't think the chroming differences would make any visible differences in output.
I think however that it may appear the outer LEDs look brighter is that you have the same # of LEDs concentrated in a smaller diameter. So you may get what appears to be, more light intensity.
Also, the outer LEDs are sunken in more, so again, light output may appear to be a bit diff.
Have to see it in person to be the real judge.
