Power Window
Power Window
Not sure if this is the right sub or not.
Well, my issue has to do with my driver's side power window. Recently it stopped working using the switch (passenger is fine). Well actually every so often it wont work with the switch, sometimes it does. I read it may be the motor going bad. One thing I did notice is that everytime i open and close the door the window does do the small drop and when i close it goes back up, that has not been affected at all. Could it be a loose wire or something? I tried it with the remote (unlock) also and that always works.
Mine was sort of like that for awhile until my driver's side window didn't go up at all. It progressively got worse and worse. For me, the window motor was the problem and I replaced it with a new one and now its fine. The window motors are pretty pricey though. I would take your car in to a window guy and have him look at it, see if he can tell what the problem is.
itgogitrev
Sep 23, 2015 07:08 PM
Paragham
Sep 15, 2015 12:04 AM
