03/04 seat buttons not working Solution
Jun 25, 2011 | 06:27 PM
are your seats stuck in gansta mode. ok i looked around and could not find a cheap solution. it could be a worn down button. so remove the two phillips screws to access buttons. then take a flat head and shimmy outfour tabs in the front of little panel(bottom). this will give you access too the forward/back buttons and i suppose you can tape something on the button too make it work all the time. any better suggestions
Reply 0
Jun 25, 2011 | 06:31 PM
oh snaps their are four more tabs after you pop out the first four tabs newb status
Reply 0
