Front Grill replacement question
Old Sep 11, 2011 | 08:04 AM
swiss-driver's Avatar
hi there
i've bought this front grill
http://intensepower.com/ingrg35co.html
but on the backside, there are no clips like in oem. (remove the oem is no problem)
how can i fix it, have i to screw it somwhere?
any tipps?
ty!
Attached Thumbnails Front Grill replacement question-p1080621.jpg   Front Grill replacement question-p1080625.jpg   Front Grill replacement question-p1080622.jpg
Old Sep 11, 2011 | 09:22 AM
MyGeeeee35's Avatar
IMO the lack of the clips to hold everything together makes it a much more difficult DIY. Check with the manufacturer, they may have a easy solution. With my personal level of experience in auto body, I'd take it to a body shop for the install or return it and buy a different one.
Good luck!
Old Sep 11, 2011 | 10:44 AM
SuperCleanG's Avatar
I had that same grille at one point and the clips on the top held it in perfectly. Once the hood is closed it will not move. Do you have an aftermarket front bumper.. because with stock it shouldn't be an issue.
Old Sep 11, 2011 | 11:33 AM
thank you
i have the stock front bumper, so i will try it.
in this case, i don't have to fix it on the bottom right?
only the clips on top?
Old Sep 11, 2011 | 11:57 AM
Yup.. 4 clips and its a wrap. I grinded of that support part in the back that you can see through the mesh.. you dont need it all.
rezendvous420
May 31, 2020 01:26 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
kinetek
Aug 3, 2015 04:25 PM
realtalk21
Jul 20, 2015 09:07 AM
