Window problem - Replaced motor, still no luck...
Old Nov 20, 2011 | 07:12 PM
akfedor7's Avatar
First off, thanks for the helpful sticky on replacing the window motor. Got a replacement motor from Advance Auto and installed it without a hitch.
Was disappointed though to get everything back together and I still seem to have the same problem: the window works about half the time. Sometimes it will go all the way up and down without trouble, sometimes will get stuck halfway or all the way down, and sometimes will not even move at all. I have also noticed that the window sometimes drops the half inch like it is supposed to upon opening the door, and sometimes it doesn't drop at all. This seemed to act the same before and after the motor replacement. So I'm assuming the motor was not the problem after all.
Any other common problems I might try before breaking down and taking it to a dealership?
Thanks for any help you might offer!
Old Nov 20, 2011 | 07:18 PM
akfedor7's Avatar
and sorry, forgot to mention my exact model. Its a 2004 coupe
Old Nov 22, 2011 | 10:56 AM
akfedor7's Avatar
Any ideas at all? Also I guess I should mention that through all this the passenger window works perfectly. I'm thinking it has to be some type of connection problem. Any common areas I should check for this? Thanks again
Old Nov 22, 2011 | 02:20 PM
saywat?'s Avatar
id check the harness make sure all the wires are tight in the there and try another switch. anyone know if the passenger side switch can be plugged intot he driver side harness? also when u test the window both switches need to be plugged in if i recall correctly
Old Nov 23, 2011 | 09:37 PM
akfedor7's Avatar
Yeah, i was wondering that too. Thought about trying to plug the passenger switch in the driver side to test it out. Sounds like its either the switch or a loose wire somewhere. I was also curious if there might be a relay or fuse that I might could change first to save me from tearing into the door again
Old Nov 25, 2011 | 08:10 AM
akfedor7's Avatar
Also, I just realized the window seems to work one time after closing the door... It'll go down, then up, then stops working until I open and close the door again. Any possible explanation for this?
Hasanbaloch
Feb 29, 2024 08:45 PM
mike730
Jan 12, 2018 04:25 PM
will091195
Jul 27, 2015 09:19 PM
Kal Hamm
Jul 24, 2015 08:55 AM
apintojr
Jul 23, 2015 10:52 AM
