Fog Lights final question
Old Dec 28, 2004 | 08:29 PM
BremboBoy's Avatar
can I use the same piaa lights for the fog lights as the clearance lights?
Old Dec 28, 2004 | 08:50 PM
skeleton_cru's Avatar
Sedan
Yup. I have the Xtreme whites for fog, clearance, and inetrior lights.
Old Dec 28, 2004 | 08:52 PM
BremboBoy's Avatar
can I use the Super Plasma GT-X. for clearance corners or will they not work because they have 2 beams?
do the Super Plasma GT-X look good when they areused with stock headlight
Old Dec 28, 2004 | 09:21 PM
waijai's Avatar
i.love.gold
Sounds like you really want the Super Plasma GT-X, so just buy them. Don't look for the approval of others. Mod the car how you see fit, and enjoy it while you can.
Old Dec 28, 2004 | 10:57 PM
BremboBoy's Avatar
im just curious if the 5000k beam will better match the stock headlight than the 4000k extreme white
Old Dec 29, 2004 | 12:09 AM
Sedan
Whatever you decide to get, I would suggest you get all the same line to better color match.
Here is what I did...
(2) HIGH BEAM/FOG PIA-15260
(2) CLEARANCE PIA-19172
(2) REVERSE PIA-19224
(1) LICENSE PLATE PIA-19172
(2) SPOT LIGHTS (FRONT DOMES) PIA-19223
(2) REAR PERSONAL (REAR DOMES) PIA-19223
(1) TRUNK LIGHT PIA-19172
They are all PIAA Xtreme White bulbs.
Old Dec 29, 2004 | 10:00 AM
GR8TG35's Avatar
The clearance and side markers can match the bulb you use for the fog/high.
I went with Piaa Extreme White blub (not LED)
and I used MTEC Super White 4350temp/color H4 fog/high
I think IMO they match well......
I'm thinking of going to a 6000K low beam, probably the Philips ultinon, and then I will have to figure which lights to upgrade my fog/high and clearance/clears to
Heres a couple shots of my car as it is w/the Piaa/MTEC set up.....The head on shot with the lows/fog is overexposed, it doesn't give off that much glare in person...
Hope this helps
Attached Thumbnails Fog Lights final question-pic001rev.jpg   Fog Lights final question-pic002rev.jpg   Fog Lights final question-pic009rev.jpg   Fog Lights final question-pic004rev.jpg   Fog Lights final question-pic006rev.jpg
Old Dec 29, 2004 | 11:35 AM
BremboBoy's Avatar
thanks 4 the pics
i was doing a bit of research on the bulbs, but arent they very high wattage.
how long have u had yours?
is this the right bulb:
Here
u just plugged in the bulbs, right?
Old Dec 29, 2004 | 01:24 PM
GR8TG35's Avatar
They look the same as mine, but a different #, I think thats just the picture....mine are #MT-439 (H4) wattage 60/55W - 130/110W
look here-autospeedy.com
This is where I ordered mine about this time last year.....
So far all the bulbs, Piaa's and the MTEC's have held up great..... The MTEC's are on everytime I use my headlights, so they get a pretty good workout....
You take out the stock bulbs, and replace with the MTEC's
Make sure you don't touch the bulbs with your fingers, To play it safe wear a pair of latex gloves, but don't touch the glass part at all.....
check this tread for install procedures http://members.rogers.com/chrisg35c/g35lights.html
Jusseth
Sep 13, 2020 12:25 PM
Freddy07g35
Sep 17, 2015 08:53 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
attarday
Jul 15, 2015 04:03 PM
