headlight holds moisture/water
Old Jan 23, 2012 | 06:16 PM
adwizard's Avatar
Question headlight holds moisture/water
Hi. 2004 G35x AWD Sedan. Whenever I go through a car wash and get an underbody flush, my passenger side headlight gets water and moisture in it. Not flooded but enough to make me nervous. The driver's side is fine. Any way to check the headlight(s) frame or around the headlight to see if there are any "leaks"? What might I look for? Looks fine from the outside. Thanks for sharing your expertise.
Old Jan 23, 2012 | 06:23 PM
saywat?'s Avatar
no i dont think theres a way to see where its leaking. better to jus open it up and reseal
Old Jan 23, 2012 | 06:44 PM
Dragonslayer's Avatar
+1 to saywat? It is better to just reseal the light. I had the same issue with my vehicle but it was covered under warranty and it cost them $1900.
Old Jan 25, 2012 | 02:58 PM
TunerMax's Avatar
G35
Yes, but you don't need to open it to reseal it. You're more likely to cause more damage doing that.
Just remove it, and run a heatgun around and around the seal area (where the lens meets the plastic housing). Aiming the gun from the plastic housing side (rear of headlight) will lower the chance of damage to your lens, and allow you more control.
if at any time the plastic starts looking glossy, you're getting it way too hot.
That should fix your issue.
For good measure, you can grab one of those small packets of "silica gel" from any craft store and put it inside the headlight, it'll clear out minor moisture as well.
Dallsinghjr1
Sep 17, 2023 11:25 AM
jeffbdye
Jun 1, 2018 03:51 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Batfinity
Lights
Sep 27, 2015 12:29 AM
