Notices
Sponsored By:
Sponsored By:
Paddle Shifter Wiring
Old 02-16-2012, 10:13 PM
jkwinner12's Avatar
I've been reading a DIY from infinitiscene over and over. but have two things I can't understand.
I'm a newb and I shouldn't have tried it but went ahead and did it. but seems like it failed.
http://www.infinitiscene.com/forum/t...addle-shifters
This is how he made his relays to handle up and down shift.
everything is straight forward except wires that needs to be ground and two wires connect to the paddles.
What I did was to wire up shift paddle to the red spot of the 1st relay then the other to the left prong of the relay then grounded it. same for the down shift.
So except two wires from each shifter, I think everything else was hooked up correctly since I can shift using the shifter. I just can't figure out what to do with the rest of wires from paddles.
Help!
Ninjay16
Audio/Video/Electronics
11
02-26-2018 06:14 PM
prinny
11-22-2015 11:07 PM
BfloG35
10-16-2015 05:22 PM
9tray turbo
09-29-2015 10:22 PM
the93owner
09-28-2015 10:37 PM
Quick Reply: Paddle Shifter Wiring
