Shift Knob Removal
Old Mar 4, 2012 | 12:22 AM
sidewayzsedan04's Avatar
Shift **** Removal
Ok guys, I'm going to feel embarrassed for asking this but is there some secret for removing the shift **** on this car, 2004 G35 sedan 6mt? I've tried muscling it off but it won't budge and it feels like I'm going to break the shifter. Thanks in advance
Old Mar 4, 2012 | 12:25 AM
Shanes_G's Avatar
STOP. do not try to turn it like that. you will mess you shlt up bro. you need to twist it off with vice grips and a sliding jaw plier, also use radiator hose so you dont damage it.
Old Mar 4, 2012 | 12:27 AM
Shanes_G's Avatar
https://g35driver.com/forums/body-in...lled-pics.html
Shanes_G's Avatar
all you had to do was search, google is a much better search engine.
ahhh...wow I feel slightly retarded for not thinking about that...thanks man!
Old Mar 4, 2012 | 12:30 AM
Shanes_G's Avatar
yea i almost made the same mistake. but take your time with the pliers bc it is still hard to break free. at least mine was.
Old Mar 4, 2012 | 01:54 AM
.cakestar's Avatar
When i was doing this i was very worried about the pliers leaving marks on the shifter and **** so i actually came up with the perfect solution. I took some clear 1/8 in plastic tubing and split it down the middle so its just like a thin long strip, i wrapped this around the shifter and the **** and material was perfect to keep a strong grip on the parts yet thick enough to prevent the wrenches from leaving marks
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Picture Share
Feb 4, 2018 12:41 PM
dcsbh1
Oct 1, 2015 03:15 PM
blnewt
Sep 25, 2015 01:48 PM
