Teh Nismo Front is on!!
Old Jan 10, 2005 | 05:14 PM
  #31
b0hr's Avatar
Originally Posted by wickedG35
No, you cannot access the tow hook. The tow hook opening is just shaped like the Nismo one but is solid and molded to the bumper. Even if you put a hole through it, you would need to make a custom center piece that can pop on and off if you need to get to it.
Totally WRONG. Thats the stock peice from my OEM bumper in there
Old Jan 10, 2005 | 05:28 PM
  #32
afr0puff's Avatar
Supa Dupa Moderator
Perfect fit, or did you shop have to modify the square?
Old Jan 10, 2005 | 05:45 PM
  #33
bzabodyn's Avatar
Simply beautiful... first one I've seen on BS - I've been back and forth with this and now I know this is definitely the bumper I have to get - do you have the factory splash guards as well? I'm contemplating on whether I should keep the f/r splash guards or replace the front ones with the ING +1 sideskirts...
the only difference is that I'm going to paint the insides of the inlets black and get a Gialla Grille...
Old Jan 10, 2005 | 07:32 PM
  #34
b0hr's Avatar
No splash guards. I'm waiting a few weeks to put some flat black vinyl on to see how I like the black ducts as well. I also did this tonight. Cant deceide whether or not to leave it
Old Jan 10, 2005 | 10:42 PM
  #35
wickedG35's Avatar
Yeah but the stock piece does you no good because the hook spot doesn't go through the whole bumper. Allow me to demonstrate...
TYPE-N FRONT BUMPER
Here is what you see w/o the OEM center piece:
And here is what it looks like from the back:
Notice how you can't get to the hook. You'd have to have the body shop cut a hole for the hook if you wanted to access it.
Old Jan 11, 2005 | 12:13 AM
  #36
b0hr's Avatar
TYPE-N FRONT BUMPER
Thats why we have dremels. You implied that the stock square would not fit even if i cut the hole. But I just cut the backing off and my stock square clips right in. Dont take it as me attacking you, but you said it wouldnt work
Old Jan 11, 2005 | 02:03 AM
  #37
wickedG35's Avatar
Right which means you had to 'MODIFY' the bumper to be able to access the tow hook. Even though the tow hook cover fits over the bumper, you cannot access the tow hook without modifying the bumper.
Old Jan 11, 2005 | 11:13 AM
  #38
b0hr's Avatar
I never said you didnt have to make a hole, just that the stock center peice would work with that bumper and you would not need a custom peice
Old Jan 11, 2005 | 02:43 PM
  #39
b0hr's Avatar
But anyways, great choice in bumpers. I'm not gonna get all involved in something regarding a towhook. Am I the first to actually keep it? I kno joe and the black one both got rid of it
Old Jan 12, 2005 | 04:54 PM
  #40
G35_coupe_6MT's Avatar
I still prefer the stock non aero. I like the kenstyle back bumper more than stock tho and also the impul back one.
Old Jan 12, 2005 | 10:46 PM
  #41
joenismo's Avatar
When I had to have my car towed I needed to pull off the front bumper. This sounds like a chore, but I can have my bumper off in five minutes so it isn't that big of a deal to me to not have a functional tow hook square. To each is his own.
Old Jan 13, 2005 | 05:25 AM
  #42
xkoraznboix's Avatar
20 Year Member
nismo kit is HOT... congrat!
Old Jan 13, 2005 | 11:26 AM
  #43
b0hr's Avatar
Did you match that line that was running down the middle of the bumper?
Old Jan 13, 2005 | 10:16 PM
  #44
tony's Avatar
Awesome man! Did you use black mesh for the lower holes? Mine is sitting in my garage, going to get painted + installed soon! It will be the first black one on a black G.
ahh...correction.. second.
Love the grill and your car looks great!
Old Jan 14, 2005 | 12:51 PM
  #45
joenismo's Avatar
Yes I did match that body line. I just don't like the look of the square. BTW the black G35 looks great.
