3rd brake light
Old Oct 13, 2012 | 09:29 PM
michael454rs's Avatar
Smile 3rd brake light
need some some help on installing an led strip on the third brake light. my as most of them has broken and i dont want to buy a new one and there are some problems with people sending them out to led marker. im planning on using this strip
http://www.ebay.com/itm/ONE-RED-ADD-...f01baf&vxp=mtr
my question is can i just cut the the connector of the old led board and hook it up the cable of the new strip and plug everything back up or do i have use a fuse somewhere?
Old Oct 16, 2012 | 01:31 AM
randyky's Avatar
No, don't do that! It doesn't work. I just went through the same thing a over the summer. The third brakelight is on its own higher voltage system independant from the rear brakelights. The two diods and resister used on the circuit board has to be incorporated into the LED strips if the diods or resister aren't faulty. I'm working with an electronics guy to remedy that problem on my 07 G35 coupe. I will post more info on the progress.
Old Oct 18, 2012 | 01:36 AM
no way really i just hacked up the old board and was lookind for a wat to mount the strip. what did you try to when you attempted to incorporate the led's
SiMpLyMoDiFiEd
The FX-Spot
Dec 2, 2021 04:35 PM
mike730
Jan 12, 2018 04:25 PM
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
Ednica87
Sep 5, 2015 02:59 AM
Lsantana757
Jul 20, 2015 09:08 AM
