Actuator or Lock
Actuator or Lock
Sorry for another actuator thread and I have searched but my problem seems a little different.
I went for a drive yesterday and the drivers doors wouldn't unlock with either my fob or the key in the lock. There is resistance from lock and when I use the fob there are no flashes unless I press the lock button. I ended up going through the trunk and opening it using the switch to unlock the but if I use fob or key nothing happens for locking or unlocking regarding the locking mechanism it self. I don't fancy leaving the car unlocked or climbing through the trunk each time so hoping for some help/advice.
I'm wondering if I replace the actuator will this solve my problem or is it something else freezing up?
Cheers in advance
Niall
P.S Passengers door doesn't move either but never has(actuator gone)
Cheers in advance
Niall
Idk if my car is special or if it comes stock in the g35's but press and hold your unlock on the fob to see if your windows lower down, I got that problem as well, been thinking of getting the actuator fix posted up all over on here
Freeman186
Sep 6, 2023 10:07 AM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
master111
Oct 6, 2015 01:36 AM
