installing impul side skirt
Old Mar 15, 2016 | 04:54 PM
JOKER's Avatar
CLUB MODERATOR
Step aside boiz and girls. Let the pros handle zis.
Here is what you do.
1. Attach both front and rear of the impull side by the front and rear wheels. (couple of screws in the OEM holes). Make sure you first line everything up with the quarter panel and front fender. You can use painters tape to tape the skirt to the QT panel to hold it while you attaching it.
2. Once you are attached on both ends you can start attaching the door part.
Your OEM clips will not work. Throw them out, bury them in your backyard, let the nature take it course and turn them into OIL. Call me when that happens I'd want some commissions!
Use these fancy things instead
http://www.ebay.com/itm/10-Qty-Headl...dVm9kr&vxp=mtr
You don't need the bolt, you just need the plastic clip from this. Trow the bolt out.
3. Go to your local hardware store and pick up some nice stainless steel bolts that are same size as those that came with them plastic clips. Make sure they have a large head.
Something like this
or like this
4. Install the plastic clips in the OEM holes, drill the correct size hole in the skirt that corresponds with the plastic clip hole and install the bolts.
5. In some cases you will need to put bunch of washers between the skirt and the car to make sure it stays straight, so make sure that the bolts you get are long enough to handle few washers. Get at least an inch and a half long bolts and few washers that you can stack between the skirt and the car to level it out as needed.
6. There are no attachment points on the skirt (as I know of) on the quarter panel side, so you just get it as tight as you can to the QT panel with bolt in the door, in the wheel well and under the car. If the QT panel part sticks out too much, adjust your under the car mount points by pushing it further under the car or pulling it out more.
7. Under the car use OEM attachment spots and screws. Just drill the holes in the skirt in the corresponding spots.
Old Mar 15, 2016 | 04:56 PM
JOKER's Avatar
CLUB MODERATOR
Originally Posted by Albanian122
anyone have any issues with impul sides having tiny pinholes when they are prepped for paint. Shop said fitment sucks on these things FML
I bought my impul sides from Concept Z
poly or fiberglass?
Old Mar 15, 2016 | 04:57 PM
JOKER's Avatar
CLUB MODERATOR
I'll snap some pix of mine later once the car is home.
Old Mar 15, 2016 | 04:58 PM
Albanian122's Avatar
Originally Posted by JOKER
poly or fiberglass?
Poly
Old Mar 15, 2016 | 05:03 PM
JOKER's Avatar
CLUB MODERATOR
Poly
your shop sux, they don't know how to prep poly.
Poly is very pores material, has lot's of holes, needs to be prepped for paint properly. Fitment will depend on the manufacturer. None of them are 100% fitment. All aftermarket body panes are like Russia and USA relationship. They requite allot of sand paper and bondo diplomacy to make it work.
Old Mar 15, 2016 | 05:08 PM
trying to get anything done in this shitty state is like pulling teeth lol I wish I was in SoCaL
Old Mar 15, 2016 | 10:41 PM
saywat?'s Avatar
I used the stock side skirt screws on each side when I had my ings on
Old Mar 18, 2016 | 02:10 PM
So the skirts ended up fitting with screws fitment near the back wheels is a little off
Any suggestions? ?
Old Mar 18, 2016 | 02:17 PM
saywat?'s Avatar
either drill a bigger hole or another hole and fill in the old hole. do it till its right. theres no reason for the screw not to be able to screw in properly.
R350k5
Oct 1, 2015 08:41 PM
erickLA
Aug 20, 2015 09:53 PM
yoyoyo8
Aug 12, 2015 03:04 AM
st33zygill
Jul 29, 2015 10:05 PM
Kz_Ed
Jul 23, 2015 02:41 AM
