2005 G35 Ext Driver Door Lock Button Not Working
Old Jul 30, 2013 | 03:52 PM
biggs35x's Avatar
Here is the scenario, cause I am finding a lot about when the door actually won't unlock at all. My locks work, the buttons inside the car work the locks, the button on my key fob work my locks fine. I am talking about the button incorporated into the door handle on the outside of the car on the drivers side. Mine does not do anything, now here is the weird part, the passenger side button works fine. One press for that door, two presses for all doors, press again to lock. Is this something anyone else has run into, A visual inspection of it, seems to be fine, the weather proofing is intact. Just wondering if this is something anyone else may have run into before I start ripping the door apart. Thanks
Adam
Old Oct 5, 2013 | 12:57 PM
Hogbone's Avatar
I have the same problem! Have you had any luck on how to fix this problem?
Old Oct 7, 2013 | 09:51 AM
biggs35x's Avatar
No I have a clue, but just haven't had a chance to tear the door apart to isolate what needs to be replaced. Hopefully in the next couple weekends. I'll keep you posted.
Old Feb 19, 2015 | 09:07 PM
JoshNjuice's Avatar
Did you ever figure this out? I'm having the same problem. Only the driver's side, but the button doesn't work anymore.
R350k5
Oct 1, 2015 08:41 PM
will091195
Jul 27, 2015 09:19 PM
AustinErkl
Drivetrain
Jul 18, 2015 05:44 PM
Scredeur4
Steering & Suspension
Jul 17, 2015 06:30 AM
